ESPHOME esp32-s3 wroom camera board with an ov5640 camera
This code works but the image has a purple tint. If I lower the mhz to 10 it is better but still has a green and blue tint
Thanks,
Grey
esphome:
  friendly_name: esp32-camera
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "<snip>"
ota:
  password: "<snip>"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32-Camera Fallback Hotspot"
    password: "<snip>"
captive_portal:
external_components:
  - source:
      type: git
      url: https://github.com/MichaKersloot/esphome_custom_components
    components: [ esp32_camera ]
esp32_camera:
  external_clock:
    pin: GPIO15
    frequency: 20MHz
  i2c_pins:
    sda: GPIO4
    scl: GPIO5
  data_pins: [GPIO11, GPIO9, GPIO8, GPIO10, GPIO12, GPIO18, GPIO17, GPIO16]
  vsync_pin: GPIO6
  href_pin: GPIO7
  pixel_clock_pin: GPIO13
  #power_down_pin: GPIO33
  # Image settings
esp32_camera_web_server:
  - port: 8080
    mode: stream
switch:
  - platform: restart
    name: "ESP32 Camera Restart"
  - platform: uptime
    name: "ESP32 Camera Uptime Sensor"
  - platform: wifi_signal
    name: "ESP32 Camera WiFi Signal"
    update_interval: 60s
You use an external component, and yet you come here for help?
Have you asked the author?
