ESPHome ESP32 WiFi connected LED
I need to have a ‘WiFi connected’ LED for my ESP32.
I can figure out how to use the wifi.component in a condition but how do I use to turn on an LED when connected and off when disconnected.
This is probably really simple but I’m stuck.
Any ideas?
I’m going to guess you’re using ESPHome … check this: https://esphome.io/components/wifi.html?highlight=wifi%20connected#wifi-connected-condition
Thanks. I’ve amended the title accordingly.
I’d already seen the wifi.connected element. I just can’t figure how to use that to drive an output.
It needs a trigger, like on_press, for example.
I need something like:
on-wifi.connected
then:
switch.turn_on: wifi_led
Simple as that, but how?
This is how I do it:
interval:
  - interval: 1s
    then:
      if:
        condition:
          wifi.connected:
        then:
          - switch.turn_on: blue_led
        else:
          - switch.turn_off: blue_led
I haven’t found a better way other than polling the sensor.
Thank you!
Hate to bring this up again, but is it a switch or a light? I am trying this but am getting errors.
ID 'blue_led' of type esp8266_pwm::ESP8266PWM doesn't inherit from switch_::Switch.
Please double check your ID is pointing to the correct value.
id: blue_led [source /config/esphome/switch_back_4ch.yaml:95]`
This is what I have in the yaml…
output:
  # Register the blue LED as a dimmable output ....
  - platform: esp8266_pwm
    pin: GPIO13
    inverted: True
light:
  # ... and then make a light out of it.
  - platform: monochromatic
    name: "Sonoff 4CH Blue LED"
    output: blue_led
interval:
  - interval: 1s
    then:
      if:
        condition:
          wifi.connected:
        then:
        else:
I am also getting errors with light.turn_on as well. What should I be using? Thanks in advance.
blue_led is an output, not a switch. Therefore you cant use the switch.turn_on/off actions. Use the output.turn_on/off actions instead.
interval:
  - interval: 1s
    then:
      if:
        condition:
          wifi.connected:
        then:
          - output.turn_on: blue_led
        else:
          - output.turn_off: blue_led
Tom, thanks for this! I “took the liberty” to use your solution in my setup, too. However, i modified it a bit, so i get a blinking led. I guess that as a side effect i’ll get a visual indication if by any chance module freezes (led will stop blinking).
interval:
  - interval: 1s
    then:
      if:
        condition:
          wifi.connected:
        then:
          - switch.turn_on: test_wifi_connected
          - delay: 500ms
          - switch.turn_off: test_wifi_connected
        else:
I went a bit further: i programmed my LED so that i know if it’s only connected to wifi or if it’s also connected to HA. “Wifi only” shows by steady 0,5s flashing, while api connected i get pulsed flashing. Ok, i admit, usability is questionable at this point… maybe it will prove usefull.
interval:
  - interval: 1s
    then:
      if:
        condition:
          wifi.connected:
        then:
          - if:
              condition:
                api.connected:
              then:
                - delay: 200ms
                - delay: 200ms
              else:
                - delay: 500ms
                - delay: 500ms
        else:
I know this is old topic, but maybe it will help someone looking for a solution.
I was also looking for a way to control an LED on wifi connect/disconnect state and you can directly configure this in the wifi component like so:
wifi:
  #your wifi settins
  on_connect:
    - switch.turn_on: switch1
  on_disconnect:
    - switch.turn_off: switch1
True, but in this case you don’t know if esp module by any chance locks up, or in any way “go south”. Although rare, it may happen, so it’s better to make led flash in regular intervals.
What about this?
output:
  - platform: gpio
    pin: 12
light:
  - platform: binary
    output: led_wifi
    effects:
      - strobe:
          colors:
            - state: true
              duration: 500ms
            - state: false
              duration: 500ms
      - strobe:
          colors:
            - state: true
              duration: 200ms
            - state: false
              duration: 200ms
wifi:
  ssid: !secret wifi_ssid
  enable_on_boot: True
  on_connect:
    then:
      - light.turn_on:
          effect: blink_slow
  on_disconnect:
    then:
      light.turn_off: wifi_led
api:
  #YOUR CODE
  on_client_connected:
    - if:
        condition:
          lambda: 'return (0 == client_info.find("Home Assistant "));'
        then:
          - light.turn_on:
            effect: blink_fast
  on_client_disconnected:
    - if:
        condition:
        then:
          - light.turn_off: wifi_led
I think this solution is better because when I was using the condition api.connected, it was triggering also if any other api connected, not just home assistant.
Only downside I have encountered with this new approach is that sometimes it takes about 1-2min till the esp realizes that it connected/disconnected to home assistant.
Hm…
first “error” i see in your version is this situation:
  • wifi connects → blink slow = ok
  • api connects → blink fast = ok
  • (later) if api disconnects → led off = NOT ok → you can’t tell if esp is still connected to wifi or not, since this command turns off led, while wifi component doesnt turn on slow blink again. So, here more sophisticated “if” would be required, like if wifi is connected → slow blink, otherwise → led off.
However, i can’t really see why there would be 1-2 minutes delay here…?
My version with interval is now a bit different - it uses flash lentgh:
(substitution “connected_pin” must be defined)
interval:
  - interval: 2s
    then:
      if:
        condition:
          wifi.connected:
        then:
          - if:
              condition:
                api.connected:
              then:
                - light.turn_on:
                    flash_length: 100ms
              else:
                - light.turn_on:
                    flash_length: 1000ms
        else:
          - light.turn_on:
              flash_length: 1900ms
light: # ----------------------------------------------------------------------- LIGHT
  - platform: binary
    internal: true
    output: status_ledica_out
output:
  - id: status_ledica_out
    platform: gpio
    pin: ${connected_pin}
But, i think that even in my config there is an option to include “client_info” or “client_ip” into condition. It’s just a matter of knowledge (or trial/error)
how i was guided to do it in a simple way that would pulse when the wifi wasnt connected and solid when it is connected:
binary_sensor:
    name: Wifi Connection
    lambda: return id(wifi_id).is_connected();
    on_press:
      then:
        - light.turn_on:
            effect: none
    on_release:
      then:
        - light.turn_on:
            effect: Pulse
output:
    pin: GPIO13
    inverted: True
light:
    output: blue_led
    internal: true
    effects:
      - pulse:
