I have some issues with uploading OTA and flashing via ESP Home Flasher code presented below. This issue starts in case of trying to use more than three MCP23017 in setup. Setup for two MCP23017 works without any issue. MCP23017 are used as port expanders (outputs) for handling multiple relays. Code compiles properly according to logs, but uploading to device leads to failure. I cannot identify source of this problem therefore I am raising this topic as bug report.
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid:
password:
ap:
ssid: "Przekazniki1 Fallback Hotspot"
password: "bk0BRkatukF7"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password:
ota:
password:
web_server:
port: 80
i2c:
sda: D1
scl: D2
scan: True
mcp23017:
- id: 'mcp23017_hub1'
address: 0x20
- id: 'mcp23017_hub2'
address: 0x21
- id: 'mcp23017_hub3'
address: 0x22
switch:
#mcp23017_hub1
- platform: gpio
pin:
mcp23017: mcp23017_hub1
number: 8
mode: OUTPUT
inverted: True
icon: mdi:electric-switch
turn_on_action:
- switch.turn_on: relay1
- delay: 500ms
- switch.turn_off: relay1
turn_off_action:
- platform: gpio
pin:
number: 9
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay2
- delay: 500ms
- switch.turn_off: relay2
turn_off_action:
- platform: gpio
pin:
number: 10
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay3
- delay: 500ms
- switch.turn_off: relay3
turn_off_action:
- platform: gpio
pin:
number: 11
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay4
- delay: 500ms
- switch.turn_off: relay4
turn_off_action:
- platform: gpio
pin:
number: 12
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay5
- delay: 500ms
- switch.turn_off: relay5
turn_off_action:
- platform: gpio
pin:
number: 13
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay6
- delay: 500ms
- switch.turn_off: relay6
turn_off_action:
- platform: gpio
pin:
number: 14
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay7
- delay: 500ms
- switch.turn_off: relay7
turn_off_action:
- platform: gpio
pin:
number: 15
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay8
- delay: 500ms
- switch.turn_off: relay8
turn_off_action:
- platform: gpio
pin:
number: 7
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay9
- delay: 500ms
- switch.turn_off: relay9
turn_off_action:
- platform: gpio
pin:
number: 6
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay10
- delay: 500ms
- switch.turn_off: relay10
turn_off_action:
- platform: gpio
pin:
number: 5
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay11
- delay: 500ms
- switch.turn_off: relay11
turn_off_action:
- platform: gpio
pin:
number: 4
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay12
- delay: 500ms
- switch.turn_off: relay12
turn_off_action:
- platform: gpio
pin:
number: 3
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay13
- delay: 500ms
- switch.turn_off: relay13
turn_off_action:
- platform: gpio
pin:
number: 2
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay14
- delay: 500ms
- switch.turn_off: relay14
turn_off_action:
- platform: gpio
pin:
number: 1
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay15
- delay: 500ms
- switch.turn_off: relay15
turn_off_action:
- platform: gpio
pin:
number: 0
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay16
- delay: 500ms
- switch.turn_off: relay16
turn_off_action:
#mcp23017_hub2
- platform: gpio
pin:
mcp23017: mcp23017_hub2
number: 8
mode: OUTPUT
inverted: True
turn_on_action:
- switch.turn_on: relay17
- delay: 500ms
- switch.turn_off: relay17
turn_off_action:
AND SO ON FOR NEXT RELAYS
Logs from ESP Home Flasher:
Using 'COM6' as serial port.
Connecting....%)Writing at 0x00048000... (100 %)Wrote 457904 bytes (306616 compressed) at 0x00000000 in 7.5 seconds (effective 488.6 kbit/s)...
Hash of data verified.
Leaving...
Hard Resetting...
Done! Flashing is complete!
Showing logs:
[21:07:35][I][logger:166]: Log initialized
[21:07:35][C][ota:366]: There have been 2 suspected unsuccessful boot attempts.
[21:07:35][I][app:029]: Running through setup()...
[21:07:35][C][mcp23017:010]: Setting up MCP23017...
[21:07:35][W][i2c:070]: Received NACK on transmit of address 0x20
[21:07:35][E][component:092]: Component was marked as failed.
[21:07:35][W][i2c:070]: Received NACK on transmit of address 0x21
[21:07:35][W][i2c:070]: Received NACK on transmit of address 0x22
[21:07:35][C][switch.gpio:011]: Setting up GPIO Switch 'relay1'...
[21:07:35][D][switch:025]: 'relay1' Turning OFF.
[21:07:35][D][switch:045]: 'relay1': Sending state OFF
[21:07:35][C][switch.gpio:011]: Setting up GPIO Switch 'relay2'...
[21:07:35][D][switch:025]: 'relay2' Turning OFF.
[21:07:35][D][switch:045]: 'relay2': Sending state OFF
[21:07:35][C][switch.gpio:011]: Setting up GPIO Switch 'relay3'...
[21:07:35][D][switch:025]: 'relay3' Turning OFF.
[21:07:35][D][switch:045]: 'relay3': Sending state OFF
[21:07:35][C][switch.gpio:011]: Setting up GPIO Switch 'relay4'...
[21:07:35][D][switch:025]: 'relay4' Turning OFF.
[21:07:35][D][switch:045]: 'relay4': Sending state OFF
[21:07:35][C][switch.gpio:011]: Setting up GPIO Switch 'relay5'...
[21:07:35][D][switch:025]: 'relay5' Turning OFF.
[21:07:35][D][switch:045]: 'relay5': Sending state OFF
[21:07:35][C][switch.gpio:011]: Setting up GPIO Switch 'relay6'...
[21:07:35][D][switch:025]: 'relay6' Turning OFF.
[21:07:35][D][switch:045]: 'relay6': Sending state OFF
[21:07:35][C][switch.gpio:011]: Setting up GPIO Switch 'relay7'...
[21:07:35][D][switch:025]: 'relay7' Turning OFF.
[21:07:35][D][switch:045]: 'relay7': Sending state OFF
[21:07:35][C][switch.gpio:011]: Setting up GPIO Switch 'relay8'...
[21:07:35][D][switch:025]: 'relay8' Turning OFF.
[21:07:35][D][switch:045]: 'relay8': Sending state OFF
[21:07:35][C][switch.gpio:011]: Setting up GPIO Switch 'relay9'...
[21:07:35][D][switch:025]: 'relay9' Turning OFF.
[21:07:35][D][switch:045]: 'relay9': Sending state OFF
[21:07:35][C][switch.gpio:011]: Setting up GPIO Switch 'relay10'...
[21:07:35][D][switch:025]: 'relay10' Turning OFF.
[21:07:35][D][switch:045]: 'relay10': Sending state OFF
[21:07:35][C][switch.gpio:011]: Setting up GPIO Switch 'relay11'...
[21:07:35][D][switch:025]: 'relay11' Turning OFF.
[21:07:35][D][switch:045]: 'relay11': Sending state OFF
[21:07:36][C][switch.gpio:011]: Setting up GPIO Switch 'relay12'...
[21:07:36][D][switch:025]: 'relay12' Turning OFF.
[21:07:36][D][switch:045]: 'relay12': Sending state OFF
[21:07:36][C][switch.gpio:011]: Setting up GPIO Switch 'relay13'...
[21:07:36][D][switch:025]: 'relay13' Turning OFF.
[21:07:36][D][switch:045]: 'relay13': Sending state OFF
[21:07:36][C][switch.gpio:011]: Setting up GPIO Switch 'relay14'...
[21:07:36][D][switch:025]: 'relay14' Turning OFF.
[21:07:36][D][switch:045]: 'relay14': Sending state OFF
[21:07:36][C][switch.gpio:011]: Setting up GPIO Switch 'relay15'...
[21:07:36][D][switch:025]: 'relay15' Turning OFF.
[21:07:36][D][switch:045]: 'relay15': Sending state OFF
[21:07:36][C][switch.gpio:011]: Setting up GPIO Switch 'relay16'...
[21:07:36][D][switch:025]: 'relay16' Turning OFF.
[21:07:36][D][switch:045]: 'relay16': Sending state OFF
[21:07:36][C][switch.gpio:011]: Setting up GPIO Switch 'relay17'...
[21:07:36][D][switch:025]: 'relay17' Turning OFF.
[21:07:36][D][switch:045]: 'relay17': Sending state OFF
[21:07:36][C][wifi:033]: Setting up WiFi...
[21:07:36][D][wifi:324]: Starting scan...
[21:07:42][D][wifi:339]: Found networks:
[21:07:42][I][wifi:385]: - ▂▄▆█
[21:07:42][D][wifi:386]: Channel: 3
[21:07:42][D][wifi:387]: RSSI: -51 dB
[21:07:42][D][wifi:386]: Channel: 12
[21:07:42][D][wifi:387]: RSSI: -67 dB
[21:07:42][I][wifi:194]: WiFi Connecting to
[21:07:44][I][wifi:457]: WiFi Connected!
[21:07:44][C][wifi:303]: SSID:
[21:07:44][C][wifi:304]: IP Address:
[21:07:44][C][wifi:306]: BSSID:
[21:07:44][C][wifi:307]: Hostname: 'przekazniki1'
[21:07:44][C][wifi:311]: Signal strength: -66 dB ▂▄▆█
[21:07:44][C][wifi:315]: Channel: 3
[21:07:44][C][wifi:316]: Subnet: 255.255.255.0
[21:07:44][C][wifi:317]: Gateway:
[21:07:44][C][wifi:318]: DNS1:
[21:07:44][C][wifi:319]: DNS2: (IP unset)
[21:07:44][D][wifi:466]: Disabling AP...
[21:07:44][C][web_server:069]: Setting up web server...
[21:07:44][C][ota:029]: Over-The-Air Updates:
[21:07:44][C][ota:030]: Address: przekazniki1.local:8266
[21:07:44][C][ota:032]: Using Password.
[21:07:44][W][ota:036]: Last Boot was an unhandled reset, will proceed to safe mode in 8 restarts
[21:07:44][C][api:022]: Setting up Home Assistant API server...
[21:07:44][I][app:059]: setup() finished successfully!
[21:07:44][I][app:105]: ESPHome version 1.16.2 compiled on Mar 27 2021, 21:05:14
[21:07:44][C][wifi:443]: WiFi:
[21:07:44][C][wifi:311]: Signal strength: -63 dB ▂▄▆█
[21:07:44][C][i2c:028]: I2C Bus:
[21:07:44][C][i2c:029]: SDA Pin: GPIO5
[21:07:44][C][i2c:030]: SCL Pin: GPIO4
[21:07:44][C][i2c:031]: Frequency: 50000 Hz
[21:07:44][I][i2c:033]: Scanning i2c bus for active devices...
[21:07:45][I][i2c:049]: Found no i2c devices!
[21:07:45]
[21:07:45]--------------- CUT HERE FOR EXCEPTION DECODER ---------------
[21:07:45]
[21:07:45]Exception (29):
[21:07:45]epc1=0x4021cd3b epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
[21:07:45]
[21:07:45]>>>stack>>>
[21:07:45]
[21:07:45]ctx: cont
[21:07:45]sp: 3ffffcf0 end: 3fffffc0 offset: 0190
[21:07:45]3ffffe80: 00000000 3fff153c 0000010c 4022722c
[21:07:45]3ffffe90: 00000003 3fff153c 00000000 4021a991
[21:07:45]3ffffea0: 00000000 00000000 00000000 00000000
[21:07:45]3ffffeb0: 3fff0000 00000000 3fff157c 401004ff
[21:07:45]3ffffec0: 00000000 3fff153c 00000002 4021b293
[21:07:45]3ffffed0: 3fffff20 3fffb624 3fff0e00 4020eacd
[21:07:45]3ffffee0: 40255266 00000000 3fff2b14 3fff2b14
[21:07:45]3ffffef0: 3fffbe3c 00002619 3fff153c 4021be9c
[21:07:45]3fffff00: 3fffac7c 4020bdcc 3fff2b14 4021a48a
[21:07:45]3fffff10: 00000000 4bc6a7f0 00002619 4020ec5a
[21:07:45]3fffff20: 3fffbe3c 00002619 3fff2b14 4020b940
[21:07:45]3fffff30: 00002619 00000000 3fff0e00 4022a400
[21:07:45]3fffff40: 00000000 00000010 3fff2dc4 4022a475
[21:07:45]3fffff50: 3fffdad0 00000000 3fff0e00 4020c6a3
[21:07:45]3fffff60: 007a1200 32b86579 feefef00 feefeffe
[21:07:45]3fffff70: 3fffbf0c 3fff8c2c 3fff8c1c 3fff8c0c
[21:07:45]3fffff80: 00000000 00000000 00000001 3fff1868
[21:07:45]3fffff90: 3fffdad0 00000000 3fff1828 4020efc8
[21:07:45]3fffffa0: 3fffdad0 00000000 3fff1828 402276c0
[21:07:45]3fffffb0: feefeffe feefeffe 3ffe8574 4010065d
[21:07:45]<<<stack<<<
[21:07:45]
[21:07:45]last failed alloc call: 4021A98C(268)
[21:07:45]
[21:07:45]
[21:07:45] ets Jan 8 2013,rst cause:2, boot mode:(3,6)
[21:07:45]
[21:07:45]load 0x4010f000, len 3584, room 16
[21:07:45]tail 0
[21:07:45]chksum 0xb0
[21:07:45]csum 0xb0
[21:07:45]v2843a5ac
[21:07:45]~ld
[21:07:45][I][logger:166]: Log initialized
[21:07:45][C][ota:366]: There have been 3 suspected unsuccessful boot attempts.
[21:07:45][I][app:029]: Running through setup()...
[21:07:45][C][mcp23017:010]: Setting up MCP23017...
[21:07:45][W][i2c:070]: Received NACK on transmit of address 0x20
[21:07:45][E][component:092]: Component was marked as failed.
[21:07:45][W][i2c:070]: Received NACK on transmit of address 0x21
[21:07:45][W][i2c:070]: Received NACK on transmit of address 0x22
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay1'...
[21:07:45][D][switch:025]: 'relay1' Turning OFF.
[21:07:45][D][switch:045]: 'relay1': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay2'...
[21:07:45][D][switch:025]: 'relay2' Turning OFF.
[21:07:45][D][switch:045]: 'relay2': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay3'...
[21:07:45][D][switch:025]: 'relay3' Turning OFF.
[21:07:45][D][switch:045]: 'relay3': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay4'...
[21:07:45][D][switch:025]: 'relay4' Turning OFF.
[21:07:45][D][switch:045]: 'relay4': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay5'...
[21:07:45][D][switch:025]: 'relay5' Turning OFF.
[21:07:45][D][switch:045]: 'relay5': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay6'...
[21:07:45][D][switch:025]: 'relay6' Turning OFF.
[21:07:45][D][switch:045]: 'relay6': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay7'...
[21:07:45][D][switch:025]: 'relay7' Turning OFF.
[21:07:45][D][switch:045]: 'relay7': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay8'...
[21:07:45][D][switch:025]: 'relay8' Turning OFF.
[21:07:45][D][switch:045]: 'relay8': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay9'...
[21:07:45][D][switch:025]: 'relay9' Turning OFF.
[21:07:45][D][switch:045]: 'relay9': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay10'...
[21:07:45][D][switch:025]: 'relay10' Turning OFF.
[21:07:45][D][switch:045]: 'relay10': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay11'...
[21:07:45][D][switch:025]: 'relay11' Turning OFF.
[21:07:45][D][switch:045]: 'relay11': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay12'...
[21:07:45][D][switch:025]: 'relay12' Turning OFF.
[21:07:45][D][switch:045]: 'relay12': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay13'...
[21:07:45][D][switch:025]: 'relay13' Turning OFF.
[21:07:45][D][switch:045]: 'relay13': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay14'...
[21:07:45][D][switch:025]: 'relay14' Turning OFF.
[21:07:45][D][switch:045]: 'relay14': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay15'...
[21:07:45][D][switch:025]: 'relay15' Turning OFF.
[21:07:45][D][switch:045]: 'relay15': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay16'...
[21:07:45][D][switch:025]: 'relay16' Turning OFF.
[21:07:45][D][switch:045]: 'relay16': Sending state OFF
[21:07:45][C][switch.gpio:011]: Setting up GPIO Switch 'relay17'...
[21:07:45][D][switch:025]: 'relay17' Turning OFF.
[21:07:45][D][switch:045]: 'relay17': Sending state OFF
[21:07:46][C][wifi:033]: Setting up WiFi...
[21:07:46][D][wifi:324]: Starting scan...
[21:07:52][D][wifi:339]: Found networks:
[21:07:52][I][wifi:385]: - ▂▄▆█
[21:07:52][D][wifi:386]: Channel: 3
[21:07:52][D][wifi:387]: RSSI: -47 dB
[21:07:52][D][wifi:386]: Channel: 12
[21:07:52][D][wifi:387]: RSSI: -65 dB
[21:07:52][I][wifi:194]: WiFi Connecting to
[21:07:54][I][wifi:457]: WiFi Connected!
[21:07:54][C][wifi:303]: SSID:
[21:07:54][C][wifi:304]: IP Address:
[21:07:54][C][wifi:306]: BSSID:
[21:07:54][C][wifi:307]: Hostname: 'przekazniki1'
[21:07:54][C][wifi:311]: Signal strength: -59 dB ▂▄▆█
[21:07:54][C][wifi:315]: Channel: 3
[21:07:54][C][wifi:316]: Subnet: 255.255.255.0
[21:07:54][C][wifi:317]: Gateway:
[21:07:54][C][wifi:318]: DNS1:
[21:07:54][C][wifi:319]: DNS2: (IP unset)
[21:07:54][D][wifi:466]: Disabling AP...
[21:07:54][C][web_server:069]: Setting up web server...
[21:07:54][C][ota:029]: Over-The-Air Updates:
[21:07:54][C][ota:030]: Address: przekazniki1.local:8266
[21:07:54][C][ota:032]: Using Password.
[21:07:54][W][ota:036]: Last Boot was an unhandled reset, will proceed to safe mode in 7 restarts
Logs from OTA update, in dev there is an error, in 1.16 ESP is not active after OTA and needs to be flashed again with basic code:
INFO Reading configuration /config/esphome/przekazniki1.yaml...
INFO Generating C++ source...
INFO Compiling app...
INFO Running: platformio run -d /config/esphome/przekazniki1
Processing przekazniki1 (board: d1_mini; framework: arduino; platform: [email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES:
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
Library Manager: Installing Update
Library Manager: Already installed, built-in library
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
| |-- <ESP8266WiFi> 1.0
|-- <ESP8266mDNS> 1.2
|-- <ESPAsyncWebServer-esphome> 1.2.7
| |-- <Hash> 1.0
| |-- <ArduinoJson-esphomelib> 5.13.3
|-- <Wire> 1.0
|-- <DNSServer> 1.1.1
Retrieving maximum program size /data/przekazniki1/.pioenvs/przekazniki1/firmware.elf
Checking size /data/przekazniki1/.pioenvs/przekazniki1/firmware.elf
RAM: [===== ] 49.6% (used 40596 bytes from 81920 bytes)
Flash: [==== ] 43.4% (used 453752 bytes from 1044464 bytes)
========================= [SUCCESS] Took 4.21 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of przekazniki1.local
INFO -> 192.168.....
INFO Uploading /data/przekazniki1/.pioenvs/przekazniki1/firmware.bin (457904 bytes)
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from przekazniki1.local using esphome API
WARNING Error resolving IP address of przekazniki1.local. Is it connected to WiFi?
WARNING (If this error persists, please set a static IP address: https://esphome.io/components/wifi.html#manual-ips)
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname). Re-Trying in 1 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname). Re-Trying in 2 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname). Re-Trying in 3 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname). Re-Trying in 5 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname). Re-Trying in 7 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname). Re-Trying in 11 seconds
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname). Re-Trying in 17 seconds
I have tried using ESPHome in ver. 1.16 and dev. Flashing via OTA and ESPHome Flasher. Flashing for two MCP’s is working properly and I am able to use with this solution 32 realys but I need much more and then this issue occurs. Can can anyone help me in this matter?
