Just upgraded to the latest version and now receiving this message. I cannot get to the webui to check logs. All ESP devices updated and are reporting to HA which is good but the add-on will not start. Here is the log:
2024-06-12 10:21:08,418 INFO 200 GET /devices (0.0.0.0) 2.73ms
2024-06-12 10:26:08,421 INFO 200 GET /devices (0.0.0.0) 4.32ms
2024-06-12 10:31:08,419 INFO 200 GET /devices (0.0.0.0) 2.03ms
2024-06-12 10:36:08,417 INFO 200 GET /devices (0.0.0.0) 1.93ms
2024-06-12 10:41:08,424 INFO 200 GET /devices (0.0.0.0) 1.88ms
2024-06-12 10:45:39,355 INFO 200 GET /devices (0.0.0.0) 3.95ms
2024-06-12 10:50:40,442 INFO 200 GET /devices (0.0.0.0) 2.46ms
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service discovery: stopping
s6-rc: info: service discovery successfully stopped
s6-rc: info: service nginx: stopping
[10:51:33] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service esphome: stopping
s6-rc: info: service init-nginx successfully stopped
[10:51:33] INFO: Service ESPHome dashboard exited with code 256 (by signal 15)
s6-rc: info: service esphome successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-timezone: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-timezone successfully stopped
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: ESPHome
ESPHome add-on for intelligently managing all your ESP8266/ESP32 devices
Add-on version: 2024.5.5
You are running the latest version of this add-on.
System: Home Assistant OS 12.2 (aarch64 / odroid-n2)
Home Assistant Core: 2024.6.2
Home Assistant Supervisor: 2024.06.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
[10:55:29] INFO: Configuring timezone (America/Chicago)...
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/30-esphome-fork.sh
cont-init: info: /etc/cont-init.d/30-esphome-fork.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service esphome: starting
s6-rc: info: service esphome successfully started
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service discovery: starting
[10:55:31] INFO: Waiting for ESPHome dashboard to come up...
[10:55:31] INFO: Starting ESPHome dashboard...
2024-06-12 10:55:32,346 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome...
[10:55:32] INFO: Starting NGINX...
2024-06-12 10:55:32,836 INFO 200 GET /devices (0.0.0.0) 3.43ms
[10:55:33] INFO: Successfully send discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
2024-06-12 11:00:32,614 INFO 200 GET /devices (0.0.0.0) 3.84ms
2024-06-12 11:05:32,609 INFO 200 GET /devices (0.0.0.0) 2.04ms
2024-06-12 11:06:40,566 INFO 200 GET /devices (0.0.0.0) 2.88ms
2024-06-12 11:09:02,885 INFO 101 GET /compile (0.0.0.0) 1.35ms
2024-06-12 11:09:02,887 INFO Running command 'esphome --dashboard compile /config/esphome/hydroponics-outside.yaml'
2024-06-12 11:11:11,839 INFO Process exited with return code 0
2024-06-12 11:11:11,847 INFO 101 GET /upload (0.0.0.0) 1.82ms
2024-06-12 11:11:11,852 INFO Running command 'esphome --dashboard upload /config/esphome/hydroponics-outside.yaml --device OTA'
2024-06-12 11:11:18,693 INFO Process exited with return code 0
2024-06-12 11:11:18,705 INFO 200 GET /devices (0.0.0.0) 5.96ms
2024-06-12 11:16:18,366 INFO 200 GET /devices (0.0.0.0) 1.96ms
2024-06-12 11:17:37,498 INFO 200 GET /devices (0.0.0.0) 2.56ms
2024-06-12 11:22:38,340 INFO 200 GET /devices (0.0.0.0) 3.38ms
2024-06-12 11:27:38,338 INFO 200 GET /devices (0.0.0.0) 1.80ms
2024-06-12 11:32:38,338 INFO 200 GET /devices (0.0.0.0) 1.84ms
2024-06-12 11:37:38,338 INFO 200 GET /devices (0.0.0.0) 1.81ms
2024-06-12 11:42:38,339 INFO 200 GET /devices (0.0.0.0) 3.28ms
2024-06-12 11:47:38,339 INFO 200 GET /devices (0.0.0.0) 1.82ms
2024-06-12 11:52:38,341 INFO 200 GET /devices (0.0.0.0) 3.61ms
2024-06-12 11:57:38,340 INFO 200 GET /devices (0.0.0.0) 3.36ms
2024-06-12 12:02:38,340 INFO 200 GET /devices (0.0.0.0) 3.33ms
2024-06-12 12:07:38,339 INFO 200 GET /devices (0.0.0.0) 2.05ms
2024-06-12 12:12:38,342 INFO 200 GET /devices (0.0.0.0) 3.24ms
2024-06-12 12:17:38,338 INFO 200 GET /devices (0.0.0.0) 1.81ms
2024-06-12 12:22:38,340 INFO 200 GET /devices (0.0.0.0) 1.78ms
I’ve tried uninstalling the add-on, restart HA, re-install add-on, won’t start. Rebooted HA and same thing. ESPHome appears in the side bar but when I click on it to get to the web UI I get the not running message. All of my IOT devices are on a IOT vlan for secuity. I can ping the IP addresses NP.
