lucazeta
(Luca Zeta)
July 24, 2022, 3:54pm
1
Hi Guys,
my sprinkler has two buttons to Start and Stop irrigation and I want to automate it by adding two relays in order to fake my finger pressing.
So on my ESPHome yaml I added two switch to control relays, and a third template switch to turn on and off “irrigation time”. Everything works but the 3rd template switch turns off by itself after 1 sec.
Can anybody suggest how to fix?
esphome:
esp8266:
board: esp01_1m
restore_from_flash: true
substitutions:
hostname: "D1 Mini Claber:"
logger:
api:
ota:
password: "xxxxx"
wifi:
ssid: !secret wifi_ssid
captive_portal:
switch:
- platform: gpio
pin: GPIO14
name: "Claber Start Relay"
inverted: yes
- platform: gpio
pin: GPIO12
name: "Claber Stop Relay"
inverted: yes
name: "Claber Aquauno Irrigation"
turn_on_action:
- switch.turn_on: D5
- delay: 500ms
- switch.turn_off: D5
turn_off_action:
- switch.turn_on: D6
- delay: 500ms
- switch.turn_off: D6
Guess that’s because of this code:
What logic is it exactly that you need? Could you explain it in a few sentences?
lucazeta
(Luca Zeta)
July 24, 2022, 5:28pm
3
Yeah.
I want to simulate my finger pressing on the physical start button for 0.5 sec (and stop button of course)
acting one relay per button
I see, maybe you need to be more optimistic and add:
optimistic: true
to your template switch
lucazeta
(Luca Zeta)
July 24, 2022, 6:26pm
5
LOL, I am, and it works properly!
Thank you.
It was intuition or did you get any working example?
Well, I was at this point long time ago And the optimistic option on the template switch is something one doesn’t forget
In case this thread ends up as monolog the waybackmachine got you covered
nickrout
(Nick Rout)
July 24, 2022, 9:04pm
7
It is basically because there is no feedback to the esp that the command has worked. ‘Optimistic’ means ‘assume it works’.
lucazeta
(Luca Zeta)
August 23, 2022, 8:24pm
8
I wish to share with you all the final YAML file that works perfectly.
esphome:
esp8266:
board: esp01_1m
substitutions:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "XXXXXXXXXXXXXXXXXXXXXXXXXX"
wifi:
ap:
ssid: "D1-Mini-Claber Fallback Hotspot"
password: "XXXXXXXXX"
captive_portal:
switch:
- platform: gpio
pin: GPIO14 #D5
inverted: yes
on_turn_on:
- delay: 600ms
- platform: gpio
pin: GPIO12 #D6
inverted: yes
on_turn_on:
- delay: 600ms
name: "Irrigazione Claber Aquauno"
optimistic: true
turn_on_action:
#reset della programmazione
- delay: 500ms
- delay: 1sec
#pressione pulsante Start
- delay: 500ms
turn_off_action:
#pressione pulsante Stop
- delay: 500ms
- delay: 1sec
- delay: 500ms
light:
- platform: status_led
name: $hostname Status LED
pin:
number: GPIO2
inverted: false
restore_mode: ALWAYS_ON
text_sensor:
- platform: wifi_info
ip_address:
name: $hostname IP Address
- platform: wifi_signal
name: $hostname WiFi Signal
icon: mdi:wifi
update_interval: 60s
Could you explain the wiring on the buttons and the ESP?
