Esphome Fan Speed Control and Google Home
Hello there,
The extractor fan speed structure, which I have shared the codes below, checked on the esphome and controlled with the switch structure, works successfully on Home Assistant.
Briefly, we have 5 buttons, the first button turns off the fan completely. Buttons two, three and four turn the fan speeds and finally the fifth button turns the light on and off.
When using it via Home Assistant, since the fan speed value remains as it is when the fan is turned off, and when I restart it, it continues from where it left off at the last run speed.
The problem is, the fan seems to be on and off constantly on Google Home, and even if the fan is off, Google Home also seems to be on all the time.
What I understand is that even if the fan is off, Google Home looked like this because it was based on the fan speed value and status at the same time.
I solved the problem as follows, I updated the fan speed value to 0 when the fan was turned off and the problem was solved.
In this structure, although the fan speed is not visible on Google Home, the fan speed can be changed in voice control.
esphome:
  platform: ESP8266
  board: nodemcuv2
  on_boot:
    then:
      - fan.turn_off: ha_mutfak_aspirator_fan
      - light.turn_off: ha_mutfak_aspirator_light
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  ap:
    ssid: "Ha-Mutfak-Aspirator"
    password: "Password"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: !secret esphome_api_password
ota:
web_server:
  port: 80
  - platform: wifi_signal
    update_interval: 60s
  - platform: adc
    pin: A0
    name: "Tehlikeli Gaz Oranı"
    accuracy_decimals: 2
    unit_of_measurement: "%"
#    on_value_range:
#      - above: 3.85
#        then:
#          - switch.turn_on: ha_mutfak_aspirator_fan
#      - below: 3.70
#        then:
#          - delay: 30s # !lambda "if (id(ha_mutfak_aspirator_fan).state) return 60000; else return 0;"
#          - switch.turn_off: ha_mutfak_aspirator_fan
  - platform: dht
    pin: D0
    temperature:
      name: "Aspiratör Sıcaklık"
    humidity:
    model: AM2302
text_sensor:
  - platform: wifi_info
    ip_address:
      name: WiFi IP Address
    ssid:
    bssid:
binary_sensor:
  - platform: gpio
    pin:
      number: D1
      mode: INPUT_PULLUP
    on_press:
      then:
  - platform: gpio
    pin:
      number: D2
      mode: INPUT_PULLUP
    on_press:
      then:
        - fan.turn_on:
            speed: 1
  - platform: gpio
    pin:
      number: D3
      mode: INPUT_PULLUP
    on_press:
      then:
        - fan.turn_on:
            speed: 2
  - platform: gpio
    device_class: cold
    pin:
      number: D4
      mode: INPUT_PULLUP
    on_press:
      then:
        - fan.turn_on:
            speed: 3
  - platform: gpio
    pin:
      number: D5
      mode: INPUT_PULLUP
    on_press:
      then:
      - light.toggle: ha_mutfak_aspirator_light
output:
  - platform: gpio
    pin: D9
    inverted: True
    type: float
    write_action:
    - if:
        condition:
          lambda: return ((state == 0) && (state < 0.3));
        then:
          - switch.turn_off: ha_mutfak_aspirator_relay_1
          - switch.turn_off: ha_mutfak_aspirator_relay_2
          - switch.turn_off: ha_mutfak_aspirator_relay_3
    - if:
        condition:
          lambda: return ((state >= 0.3) && (state < 0.6));
        then:
          - switch.turn_on: ha_mutfak_aspirator_relay_1
    - if:
        condition:
          lambda: return ((state >= 0.6) && (state <= 0.9));
        then:
          - switch.turn_on: ha_mutfak_aspirator_relay_2
    - if:
        condition:
          lambda: return ((state >= 1));
        then:
          - switch.turn_on: ha_mutfak_aspirator_relay_3
light:
  - platform: binary
    output: ha_mutfak_aspirator_output_light
fan:
  - platform: speed
    output: ha_mutfak_aspirator_output_fan
    speed_count: 3
    on_turn_on:
      then:
        - if:
            condition:
              lambda: return (id(ha_mutfak_aspirator_fan).speed == 0);
            then:
              - fan.turn_on:
                  speed: 1
    on_turn_off:
      then:
        lambda: id(ha_mutfak_aspirator_fan).speed = 0;
switch:
  - platform: gpio
    pin: D6
    inverted: true
    interlock: &interlock_group [ha_mutfak_aspirator_relay_1, ha_mutfak_aspirator_relay_2, ha_mutfak_aspirator_relay_3]
    interlock_wait_time: 100 ms
    restore_mode: RESTORE_DEFAULT_OFF
  - platform: gpio
    pin: D7
    inverted: true
    interlock: *interlock_group
  - platform: gpio
    pin: D8
    inverted: true
good works
I hope it worked.
Last code;
substitutions:
  devicename: ha_mutfak_aspirator
  deviceFriendlyName: Aspiratör
  relayInterlockWaitTime: 100 ms
  sound_Button: 'Button:d=64,o=5,b=140:f#.'
  sound_Siren: 'Siren:d=16,o=5,b=120:c.'
esphome:
  platform: ESP8266
  board: nodemcuv2
#  esp8266_restore_from_flash: true
  on_boot:
  - then:
    - fan.turn_off: ${devicename}_fan
    - lambda: id(${devicename}_fan).speed = 0;
    - light.turn_off: ${devicename}_light
    - rtttl.stop
wifi:
  fast_connect: true
  ap:
    ssid: ${devicename}
    password: "${devicename}_0tGQCjfCSzIA"
captive_portal:
# Enable logging
logger:
api:
ota:
web_server:
  port: 80
    name: ${deviceFriendlyName} WiFi Signal
  - platform: adc
    pin: A0
    name: ${deviceFriendlyName} Tehlikeli Gaz
    device_class: carbon_monoxide
    update_interval: 5 s
    on_value_range:
      - above: 0.95
        then:
        - fan.turn_on:
            speed: 3
        - while:
            condition:
              lambda: return (id(${devicename}_gas_analog).state >= .95);
            then:
              - rtttl.play: ${sound_Siren}
              - delay: 500 ms
      - below: 0.6
        then:
        - rtttl.stop
        - delay: 60 s
  - platform: dht
    pin: D0
    model: AM2302
    temperature:
    humidity:
text_sensor:
    ip_address:
      name: ${deviceFriendlyName} WiFi IP Address
    ssid:
      name: ${deviceFriendlyName} WiFi SSID
    bssid:
      name: ${deviceFriendlyName} WiFi BSSID
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: D1
      mode: INPUT_PULLUP
    on_press:
    - then:
  - platform: gpio
    internal: true
    pin:
      number: D2
      mode: INPUT_PULLUP
    on_press:
    - then:
      - fan.turn_on:
          speed: 1
  - platform: gpio
    internal: true
    pin:
      number: D3
      mode: INPUT_PULLUP
    on_press:
    - then:
      - fan.turn_on:
          speed: 2
  - platform: gpio
    device_class: cold
    internal: true
    pin:
      number: D4
      mode: INPUT_PULLUP
    on_press:
    - then:
      - fan.turn_on:
          speed: 3
  - platform: gpio
    internal: true
    pin:
      number: D5
      mode: INPUT_PULLUP
    on_press:
    - then:
      - light.toggle: ${devicename}_light
output:
  - platform: esp8266_pwm
    pin: D6
  - platform: gpio
    pin: D10
    inverted: True
    type: float
    write_action:
    - if:
        condition:
          lambda: return ((state == 0) && (state < .3));
        then:
        - if:
            condition:
              lambda: return (id(${devicename}_relay_1).state || id(${devicename}_relay_2).state || id(${devicename}_relay_3).state);
            then:
            - rtttl.stop
            - rtttl.play: ${sound_Button}
            - switch.turn_off: ${devicename}_relay_1
            - switch.turn_off: ${devicename}_relay_2
            - switch.turn_off: ${devicename}_relay_3
    - if:
        condition:
          lambda: return ((state >= .3) && (state < 0.6));
        then:
        - if:
            condition:
              lambda: return !id(${devicename}_relay_1).state;
            then:
            - rtttl.stop
            - switch.turn_on: ${devicename}_relay_1
    - if:
        condition:
          lambda: return ((state >= .6) && (state < .9));
        then:
        - if:
            condition:
              lambda: return !id(${devicename}_relay_2).state;
            then:
            - rtttl.stop
            - switch.turn_on: ${devicename}_relay_2
    - if:
        condition:
        then:
        - if:
            condition:
              lambda: return !id(${devicename}_relay_3).state;
            then:
            - rtttl.stop
            - switch.turn_on: ${devicename}_relay_3
rtttl:
  output: passive_buzzer
light:
  - platform: binary
    output: ${devicename}_output_light
    on_turn_on:
    - then:
      - rtttl.stop
    on_turn_off:
    - then:
      - rtttl.stop
fan:
  - platform: speed
    output: ${devicename}_output_fan
    speed_count: 3
    on_turn_on:
    - then:
      - if:
          condition:
            lambda: return (id(${devicename}_fan).speed == 0);
          then:
            - fan.turn_on:
                speed: 1
    on_turn_off:
    - then:
switch:
  - platform: gpio
    pin: D7
    inverted: true
    internal: true
    interlock: &interlock_group ['${devicename}_relay_1', '${devicename}_relay_2', '${devicename}_relay_3']
    interlock_wait_time: ${relayInterlockWaitTime}
  - platform: gpio
    pin: D8
    inverted: true
    internal: true
  - platform: gpio
    pin: D9
    inverted: true
    internal: true
