I have an ESPHome installed in my pool controller box. Connected to it I also have a dallas temp sensor. A couple times a week I get a bad reading, its spike at 185F. I’m sure it from the electrical interference in the panel.
I was wonder how I could add a filter to my sensor to not transmit any reading above 50c or 122f
Yes it is a wiring error being sent from the sensor. It only happens like 1-2 times a week. I’m 99% sure it’s electrical interference from the 220v panel it’s installed in.
The error is rare and not a big deal, but it messes up the history graph.
Your original reply didn’t contain a signal word. In addition how would one setup the sensor, if they didn’t read the instruction on how to setup the sensor or converting temperature? So yes you are correct that is the document I originally used to set up my sensor prior to asking for additional help, but there is not an example there on how to filter out a range of readings.
I’m positive you know much more about HA and coding than I do, so a little of your knowledge here would have been appreciated is all, just like every other poster here did.
