I need help with a config I can’t make work as intended. I want to filter invalid ultrasonic sensor readings and then use a sliding time window of those filtered values to set the state of a binary sensor.
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "SSID"
password: "PSK"
- platform: ultrasonic
# Setting ID only will make the sensor internal
trigger_pin: D1
echo_pin: D2
accuracy_decimals: 5
update_interval: 1s
filters:
- lambda: if (x > 0.2000 && x < 0.6500) return x; else return {};
- sliding_window_moving_average:
window_size: 5
send_every: 5
- platform: uptime
name: "Desk Keyboard Tray Uptime"
text_sensor:
- platform: wifi_info
ip_address:
name: "Desk Keyboard Tray IP Address"
binary_sensor:
name: "Desk Keyboard Tray"
device_class: opening
lambda: if (id(ultrasonic_sensor).state > 0.34) return true; else return false;
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
So I only want values > 0.2000 and < 0.6500 to be used in the sliding window. This doesn’t seem to be working like I want. Help?
Did you ever get this working? Is the sliding_window_moving_average called with the raw values from the sensor before the lambda function is called? If so, is there another solution?
In my case I’m trying to use the vl53L0X time-of-flight sensor at the NaN values (out of range) is messing up the average as the numbers are thrown out for the average. I’d like to make the NaN values to be 999.
Looks like filters are processed in the order they are defined. That is great news. So my solution was to perform a lambda filter to make NaN into 999. Then the sliding_window_moving_average filter would use the value returned from the lambda filter to perform the average. The solution was easier than I thought. You have to love ESPHome.
Only loosely related to the OP but just for those who come here by search because their average or median filters act strangely:
When your sensor returns “unknown” values (ESPHome internally: nan = not a number), the average filters consider this to be a zero value instead of discarding it. At least the median filter does that but I am quite sure the other average filters do the same.
To prevent your filter output from falsely reporting zero you can prepend the averaging / median filter by a filter_out filter like this:
filters:
- filter_out: nan # <-- Processing will stop here on unknown values.
- median:
window_size: 5
