I’m encountering a peculiar Wi-Fi connectivity issue with BK-Chip Curtain Modules supported by the LibreTiny platform of esphome. The modules were flashed using tuya-cloudcutter. Out of the 9 modules I purchased, I’ve successfully flashed two without any issues. However, the third module is exhibiting strange behavior after flashing.
Environment:
Product Type: Wi-Fi Curtain Modules (BK-Chips)
Platform: LibreTiny (esphome)
Flashing Tool: tuya-cloudcutter
Total Devices: 9 (all from the same shop)
Observed Behavior:
On the third module, after flashing:
The status LED blinks continuously.
It connects to Wi-Fi but redirects to the Wi-Fi chooser page on the web interface.
Changing the logger level from INFO to DEBUG resolves the issue, and the module functions properly.
Reverting back to INFO logger level brings back the problem.
Recompiling with DEBUG logger level again makes the module work correctly.
Additional Information:
Another module from the same batch works fine with INFO logging level.
Suspected issue: Flash memory might be corrupted at certain addresses. Recompiling with DEBUG logging seems to shift the code, avoiding these addresses.
Request for Community Assistance:
Has anyone experienced similar issues with BK-Chip modules or similar hardware?
Could the logger level affect the stability or functionality of these modules in this manner?
Any suggestions or potential solutions to ensure stable operation with INFO logging level?
Additional Context:
I have concerns about running devices on DEBUG logging level due to past experiences with other devices.
Any insights, suggestions, or shared experiences would be greatly appreciated. Thank you in advance!
What concerns logs: when in debug log level, it boots up and works successfully. And there are no suspicious log entries. The same as in the other two (now three) devices.
We are more interested in logs when INFO logging is configured, as this is when device doesn’t work properly.
However, when in INFO log level - it pretends it did not connect to WiFi (which is false, as it gets the IP address and I land at web interface via my usual WiFi SSID). In this mode, I can only set up WiFi or upload new firmware (which I use to jailbreak from this state - upload firmware with logging set to debug).
In this mode logging doesn’t work (also not via esphome logs CLI command) - device simply doesn’t initialize the logging port. How do I get to the logs in such a case?
