Hello
I hope someone can help me. I have a generic thermostat in the HA. I have DS18b20 on ESP8266+ESPhome which is sending the temperature values in every 180 seconds. I would like more frequent (30s) temperature readings when the HA thermostat is turned on (idle/heat). I can manage this thing with DHT11 but the DS18b20 not supported by this method:
- lambda: 'id(my_component).update();'
I got compile error:
src/main.cpp: In lambda function: src/main.cpp:84:31: error: ‘class esphome::sensor::DallasTemperatureSensor’ has no member named ‘update’ livingroom_temperature->update();
I saw in the description it is not a bug: https://esphome.io/guides/automations.html?highlight=update#component-update-action
There is any other solution to force the DS18b20 reading? Or any other idea?
Thx
Part of my yaml for the better understanding:
substitutions:
upper_devicename: "Livingroom"
lower_devicename: "livingroom"
dallas:
- pin: GPIO2
update_interval: 180s
- platform: dallas
name: ${upper_devicename} Temperature
address: 0x38041750ED77FF29
###### Home Assistant Livingroom Thermostat Text State
text_sensor:
- platform: homeassistant
name: "HA Livingroom Thermostat text State"
entity_id: climate.livingroom
internal: true
###### Home Assistant Livingroom Thermostat Text --> Binary Sensor
binary_sensor:
name: "HA Livingroom Thermostat binary State"
internal: true
lambda: |-
if (id(ha_livingroom_thermostat_sensor_text).state == "off")
return false;
else if (id(ha_livingroom_thermostat_sensor_text).state == "heat")
return true;
else if (id(ha_livingroom_thermostat_sensor_text).state == "idle")
return true;
else
return {};
on_state:
- while:
condition:
binary_sensor.is_on: ha_livingroom_thermostat_sensor_binary
then:
- delay: 30s
- lambda: 'id(${lower_devicename}_temperature).update();'
