Hi @OttoWinter, Ive been using ESPhome for a while now and all seems ok, but I have just tried to compile a new file and it keeps freezing. Im using v1.12.1 on hassio 0.90.2.
I leave it for about 5 minutes, I then hit the stop button and return to hassio to find its not working and the pi is frozen with the green led flickering very fast and no response. I have to power cycle and start again.
The compile never use to take this time, I suppose I could leave it running for longer to see if it final compiles, just wondering if others have had issues.
Just restarted hassio and tried after a make clean in ESPhome and it froze again. I know its frozen because I can no longer log into my unifi controller from my phone. All I can do is pull the power and restart which I hate doing, it only seems to damage the hassio database file which I delete and all seems good again.
Unifi is on the pi, its a add-on in hassio which is how I know the hassio has crashed out because I can’t access anything on it after trying to compile.
Ill update ESPhome and see how that goes, didn’t realise there was a newer version
denver: It’s a capacity issue, a Pi (even a 3B+) has a finate amount of memory to run the quite heavy unifi and do a compilation at the same time. Just turn off your Unifi Controller, compile your code and then turn back on Unifi Controller… (Unfortunately HASSIO doesn’t have a huge amount of swap, and Raspberry PIs don’t have a huge amount of memory).
Meant to add, thanks for the original post, because without it i wouldn’t have realised that A) someone else runs the same configs I do and B) that it was a resource issue.
Obviously my problem is, also, lack of power as I am running HASSIO on an orange pi zero what it really amaze me as it is working OK, at least while working with few stuff (I am just stating on HASSIO).
I wonder how it will be on a raspberry pi 4 with 4GB RAM…
I like this raspberry like pcs as the power consumption keeps reasonable. (I like to consider power consumption being a bit more environment friendly…… Or at least less contaminating…)
Im sure it would be ok on the RPi4, I was using the RPi3 and everything work until I tried to compile the source code in ESPhome, The RPi3 just locked up and needed rebooting.
I have the similar issue. After I press compile in home assistant rpi3b freezes. But then after reboot, I can compile normally. This happens everytime I start to compile for the first time…
