ESPHome Garage Opener - check for door status on cover actions
the recent issues with MyQ got me to finally pull the trigger and setup an ESP8266 with ESPHome for the garage opener.
However one thing i found with the common code available online that is the cover code just executes the relay actions, so when sending it a cover close command it would actually open the garage door if the door was already closed.
I could set up a check in automations for the cover but thought it would be simpler to set it up at source in the ESPHome code.
Here is the common code i found online (this is one of the many variations)
switch:
  - platform: gpio
    pin:
      number: GPIO03
      inverted: true
    restore_mode: ALWAYS_OFF
binary_sensor:
  # This is the magnetic reed switch, used to determine if the door is closed.
  - platform: gpio
    pin:
      number: GPIO05
      mode: INPUT_PULLUP
    filters:
      # During testing- the reed switch was pretty noisy. This cleans up the output.
      - delayed_on: 100ms
      - delayed_off: 100ms
    internal: true
cover:
  # This template hides both the functionality to open/close the door, as well as its current state
  # behind a single "cover"
    device_class: garage
# my reed switch is in the on position when the door is closed i.e. magnet is away from the sensor
    lambda: |-
      if (id(reed_switch).state) {
        return COVER_CLOSED;
      } else {
        return COVER_OPEN;
    open_action:
      - switch.turn_on: relay1
      - delay: 0.5s
      - switch.turn_off: relay1
    close_action:
      - delay: 0.5s
to address that i added a check for the reed switch status as below
    open_action:
      if:
        condition:
          binary_sensor.is_on: reed_switch
        then:
          - delay: 0.5s
        else:
    close_action:
      if:
        condition:
          binary_sensor.is_off: reed_switch
        then:
          - delay: 0.5s
        else:
probably does not need the action on the else and there might be a more elegant solution but that what i came up with.
Athom’s Garage Door Opener based on ESPHome has a Github config that correctly deals with the door status in the cover controls.
athom-configs/athom-garage-door.yaml at main · athom-tech/athom-configs · GitHub
This device is cheap and functions well for those that don’t want to “roll your own”.
