ESPHome gives blank screen in Home Assitant
I can’t change the ESPHome config anymore. If I click on ESPHome in the navigation bar on the left there is only a blank screen. The ESP32 is still alive. I can still can use it. I reinstalled it. but no luck. When I reinstall it finds the ESP on the network.
What do the logs say?
Hi Nick,
Sorry, a bit late response.
See ESPHome log below:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: ESPHome
ESPHome add-on for intelligently managing all your ESP8266/ESP32 devices
Add-on version: 2023.4.1
You are running the latest version of this add-on.
System: Home Assistant OS 9.5 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.4.6
Home Assistant Supervisor: 2023.04.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
[21:11:41] INFO: Configuring timezone (Europe/Amsterdam)…
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service esphome: starting
s6-rc: info: service esphome successfully started
[21:11:43] INFO: Starting ESPHome dashboard…
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service discovery: starting
[21:11:43] INFO: Waiting for ESPHome dashboard to come up…
2023-04-25 21:11:45,077 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome…
[21:11:45] INFO: Starting NGINX…
[21:11:45] INFO: Successfully send discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
2023-04-25 21:12:19,457 INFO 200 GET /devices (0.0.0.0) 3.90ms
Found it. I discovered that the problem not existed in the App’s and also not in Firefox. After clearing the cache in Chrome the problem was solved.
