Hi, I am trying to get a candlelight flickering effect on an LED connected to GPIO12 on my ESP8266 board but I am stuck.
My current code is this:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: "redacted"
password: "redacted"
manual_ip:
static_ip: 192.168.3.150
gateway: 192.168.3.1
subnet: 255.255.255.0
ap:
ssid: "redacted"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
switch:
- platform: gpio
pin: GPIO12
binary_sensor:
- platform: gpio
pin: GPIO14
Currently if I switch on GPIO12 in home assistant, the LED connected between GPIO14 and Ground pin will light up. So I am hoping I am in the right path.
Now to achieve the candlelight effect, from googling, it would appear if I set this GPIO to have a PWM output of something like this:
analogWrite(14, random(120)+135);
delay(random(100));
How would I integrate the above code into the yaml file?
Thanks in advance
DidierM
(Didier Miller)
October 17, 2020, 10:30am
2
hi,
I think you should use Binary light instead https://esphome.io/components/light/binary.html
You have to specify an output component, which I have no experience with, but maybe you can find some more info somewhere.
light:
- platform: binary
output: output_component1
pin: GPIO14
Possibly you can create an effect for the light with a lambda.
Hope this helps
DidierM:
hi,
I think you should use Binary light instead Binary Light — ESPHome
Copy to clipboard
light:
- platform: binary
pin: GPIO14
Hope this helps
Thanks DidierM. You gave me some ideas. The binary platform does not allow me to add the flicker component so I modified the code to reflect this:
output:
- platform: esp8266_pwm
pin: GPIO0
frequency: 10 Hz
switch:
- platform: gpio
pin: GPIO12
light:
- platform: monochromatic
output: pwm_output
effects:
- flicker:
So when i switch on LED, I can see that it flicker 3 times before turning to full brightness, but sadly it does not flicker further.
Any ideas?
DidierM
(Didier Miller)
October 17, 2020, 12:56pm
4
Hi @fliptoback ,
well, now you can change the pwm fequency part to for example:
light:
- platform: ...
on_turn_on:
- output.esp8266_pwm.set_frequency:
frequency: !lambda |-
return(rand() % 100 + 1);
this will return a random number between 1 and 100. It automatically does this on turn on of the light.
If you put it under your effects part you can create your own effect (you will see it in the pulldown menu in HA).
hope this works!
DidierM:
Hi @fliptoback ,
Copy to clipboard
light:
- platform: ...
on_turn_on:
hope this works!
Thanks DidierM again. This time it won’t compile as it says on_turn_on is not a valid option for the platform monocromatic.
I am so close!!
Finally successful!
Here is the esphome yaml code that works for me. I have to change the board platform to nodemcuv2.
Back in home assistant all I need to do is to add the entities, select the flicker from the drop down menu and voila. Very pleased with the candlelight effect.
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: “redacted”
password: “redacted”
manual_ip:
#Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “redacted”
captive_portal:
#Enable logging
logger:
#Enable Home Assistant API
api:
ota:
light:
output: candle_pwm
default_transition_length: 0s
effects:
flicker:
alpha: 90%
intensity: 5%
output:
pin: GPIO2
frequency: 1000 Hz
Thanks! I am also very pleased!
jkmaxwell
(Justin Maxwell)
February 17, 2021, 3:41am
9
Instead of “redacted” I recommend you use a secrets.yaml file external to your config. If you’re using home assistant, just click the upper right corner of the ESPHome view.
