Currently unable to install the ESPHome add-on on Hass.io platform (running as a VM on Unraid) Have added the github and click install, fails with error below (have tried both regular and beta versions). Anyone else having the same issue? Is it possible to manually install it somehow?
20-05-31 19:08:05 INFO (MainThread) [supervisor.addons] Create Home Assistant add-on data folder /data/addons/data/15ef4d2f_esphome-beta 20-05-31 19:08:05 INFO (SyncWorker_5) [supervisor.docker.interface] Pull image esphome/esphome-hassio-amd64 tag 1.14.3. 20-05-31 19:08:34 ERROR (SyncWorker_5) [supervisor.docker.interface] Can't install esphome/esphome-hassio-amd64:1.14.3 -> 404 Client Error: Not Found ("no such image: esphome/esphome-hassio-amd64:1.14.3: No such image: esphome/esphome-hassio-amd64:1.14.3").
