SSL is set to false in the addon settings. Uninstalling and reinstalling the addon solved the issue.
Although now I have another issue, I can’t upload any code to the devices. Compiling ends up with a very long error (and its not a YAML error). Those is for EVERY device …
Compiling /data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/FrameworkArduino/uart.c.o
Compiling /data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/FrameworkArduino/umm_malloc/umm_malloc.c.o
Archiving /data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/libFrameworkArduino.a
Linking /data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/firmware.elf
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_s_recv(void*, tcp_pcb*, pbuf*, long)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_recvEPvP7tcp_pcbP4pbufl+0x4): multiple definition of `AsyncClient::_s_recv(void*, tcp_pcb*, pbuf*, long)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_recvEPvP7tcp_pcbP4pbufl+0x10): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_s_sent(void*, tcp_pcb*, unsigned short)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_sentEPvP7tcp_pcbt+0x4): multiple definition of `AsyncClient::_s_sent(void*, tcp_pcb*, unsigned short)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_sentEPvP7tcp_pcbt+0x10): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_s_error(void*, long)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient8_s_errorEPvl+0x4): multiple definition of `AsyncClient::_s_error(void*, long)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient8_s_errorEPvl+0xc): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_s_poll(void*, tcp_pcb*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_pollEPvP7tcp_pcb+0x4): multiple definition of `AsyncClient::_s_poll(void*, tcp_pcb*)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient7_s_pollEPvP7tcp_pcb+0x10): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::AsyncClient(tcp_pcb*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClientC2EP7tcp_pcb+0x30): multiple definition of `AsyncClient::AsyncClient(tcp_pcb*)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClientC2EP7tcp_pcb+0x48): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_s_connected(void*, void*, long)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12_s_connectedEPvS0_l+0x4): multiple definition of `AsyncClient::_s_connected(void*, void*, long)'
I had to cut the log since its too long, this is the end of it
data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient6_errorEl+0x4): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::_dns_found(ip_addr const*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient10_dns_foundEPK7ip_addr+0xc): multiple definition of `AsyncClient::_dns_found(ip_addr const*)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient10_dns_foundEPK7ip_addr+0xc): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::onConnect(std::function<void (void*, AsyncClient*)>, void*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient9onConnectESt8functionIFvPvPS_EES1_+0x4): multiple definition of `AsyncClient::onConnect(std::function<void (void*, AsyncClient*)>, void*)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient9onConnectESt8functionIFvPvPS_EES1_+0x4): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::onDisconnect(std::function<void (void*, AsyncClient*)>, void*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12onDisconnectESt8functionIFvPvPS_EES1_+0x4): multiple definition of `AsyncClient::onDisconnect(std::function<void (void*, AsyncClient*)>, void*)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient12onDisconnectESt8functionIFvPvPS_EES1_+0x4): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::onPoll(std::function<void (void*, AsyncClient*)>, void*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient6onPollESt8functionIFvPvPS_EES1_+0x4): multiple definition of `AsyncClient::onPoll(std::function<void (void*, AsyncClient*)>, void*)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient6onPollESt8functionIFvPvPS_EES1_+0x4): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncServer::onClient(std::function<void (void*, AsyncClient*)>, void*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncServer8onClientESt8functionIFvPvP11AsyncClientEES1_+0x4): multiple definition of `AsyncServer::onClient(std::function<void (void*, AsyncClient*)>, void*)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncServer8onClientESt8functionIFvPvP11AsyncClientEES1_+0x4): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::onAck(std::function<void (void*, AsyncClient*, unsigned int, unsigned int)>, void*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5onAckESt8functionIFvPvPS_jjEES1_+0x8): multiple definition of `AsyncClient::onAck(std::function<void (void*, AsyncClient*, unsigned int, unsigned int)>, void*)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient5onAckESt8functionIFvPvPS_jjEES1_+0x8): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::onData(std::function<void (void*, AsyncClient*, void*, unsigned int)>, void*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient6onDataESt8functionIFvPvPS_S1_jEES1_+0x8): multiple definition of `AsyncClient::onData(std::function<void (void*, AsyncClient*, void*, unsigned int)>, void*)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient6onDataESt8functionIFvPvPS_S1_jEES1_+0x8): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::onPacket(std::function<void (void*, AsyncClient*, pbuf*)>, void*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient8onPacketESt8functionIFvPvPS_P4pbufEES1_+0x8): multiple definition of `AsyncClient::onPacket(std::function<void (void*, AsyncClient*, pbuf*)>, void*)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient8onPacketESt8functionIFvPvPS_P4pbufEES1_+0x8): first defined here
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib224/[email protected](ESPAsyncTCP.cpp.o): In function `AsyncClient::onTimeout(std::function<void (void*, AsyncClient*, unsigned int)>, void*)':
ESPAsyncTCP.cpp:(.text._ZN11AsyncClient9onTimeoutESt8functionIFvPvPS_jEES1_+0x8): multiple definition of `AsyncClient::onTimeout(std::function<void (void*, AsyncClient*, unsigned int)>, void*)'
/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/lib3bd/libESPAsyncTCP_ID305.a(ESPAsyncTCP.cpp.o):ESPAsyncTCP.cpp:(.text._ZN11AsyncClient9onTimeoutESt8functionIFvPvPS_jEES1_+0x8): first defined here
collect2: error: ld returned 1 exit status
*** [/data/14a_gate_door_bridge_shelly/.pioenvs/14a_gate_door_bridge_shelly/firmware.elf] Error 1
========================= [ERROR] Took 107.72 seconds =======================
