ESPHome - Help Referring a Variable as a Condition Value
I am trying to refer a variable as a “reference value” for a condition. Example:
switch:
  - platform: gpio
    pin: GPIO12
    restore_mode: RESTORE_DEFAULT_OFF
    internal: false
globals: # I also tried with number
  - id: valor_temp_arranque_calentador
    type: float
    restore_value: yes
    initial_value: '3'  # 0..100
  - platform: sht4x
    temperature:
      name: "Temperatura Invernadero"
      on_value_range:
        - above: 4
          then:
            - switch.turn_off:
        - below: 3
          then:
            - switch.turn_on:
  - platform: homeassistant
    entity_id: input_number.inv_temp_arranque_calentador
    internal: true
    accuracy_decimals: 1
    on_value:
      then:
        - lambda: |-
            id(valor_temp_arranque_calentador) = x;
What I want to do is to use the HA variable “input_number.inv_temp_arranque_calentador” to state the temperature when “Rele_Calefacción” start or stop.
It is, change:
 on_value_range:
        - above: 4
by:
 on_value_range:
        - above: id(valor_temp_arranque_calentador).status
or something like this.
In that way I would change from HA the temperature where the relay start.
Is it possible??
Thank you in advance
Someone have any idea?
