Esphome hlk-ld2410
hi
i am using esp32 with hlk-ld2410. i hv installed it in remote location from where i want to turn on an switch when presence detected or movement detected. i dont want to use home assistant automation. here is my code
captive_portal:
uart:
  tx_pin: 17
  rx_pin: 16
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
ld2410:
  uart_id: ld2410uart
number:
  - platform: ld2410
    timeout:
    light_threshold:
      name: Light Threshold
    max_move_distance_gate:
      name: Max Move Distance Gate
    max_still_distance_gate:
      name: Max Still Distance Gate
    g0:
      move_threshold:
        name: g0 move threshold
      still_threshold:
        name: g0 still threshold
    g1:
      move_threshold:
        name: g1 move threshold
      still_threshold:
        name: g1 still threshold
    g2:
      move_threshold:
        name: g2 move threshold
      still_threshold:
        name: g2 still threshold
    g3:
      move_threshold:
        name: g3 move threshold
      still_threshold:
        name: g3 still threshold
    g4:
      move_threshold:
        name: g4 move threshold
      still_threshold:
        name: g4 still threshold
    g5:
      move_threshold:
        name: g5 move threshold
      still_threshold:
        name: g5 still threshold
    g6:
      move_threshold:
        name: g6 move threshold
      still_threshold:
        name: g6 still threshold
    g7:
      move_threshold:
        name: g7 move threshold
      still_threshold:
        name: g7 still threshold
    g8:
      move_threshold:
        name: g8 move threshold
      still_threshold:
        name: g8 still threshold
select:
  - platform: ld2410
    distance_resolution:
      name: Distance Resolution
    baud_rate:
    light_function:
    out_pin_level:
      name: Out Pin Level
binary_sensor:
  - platform: ld2410
    has_target:
      name: Male Washroom Presence
    has_moving_target:
      name: Male Washroom Moving Target
    has_still_target:
      name: Male Washroom Still Target
  - platform: ld2410
    light:
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
    g0:
      move_energy:
        name: g0 move energy
      still_energy:
        name: g0 still energy
    g1:
      move_energy:
        name: g1 move energy
      still_energy:
        name: g1 still energy
    g2:
      move_energy:
        name: g2 move energy
      still_energy:
        name: g2 still energy
    g3:
      move_energy:
        name: g3 move energy
      still_energy:
        name: g3 still energy
    g4:
      move_energy:
        name: g4 move energy
      still_energy:
        name: g4 still energy
    g5:
      move_energy:
        name: g5 move energy
      still_energy:
        name: g5 still energy
    g6:
      move_energy:
        name: g6 move energy
      still_energy:
        name: g6 still energy
    g7:
      move_energy:
        name: g7 move energy
      still_energy:
        name: g7 still energy
    g8:
      move_energy:
        name: g8 move energy
      still_energy:
        name: g8 still energy
    name: Male Washroom ESP Temperature
    lambda: return temperatureRead();
    unit_of_measurement: °C
    device_class: TEMPERATURE
    update_interval: 5s
    entity_category: "diagnostic"
  - platform: uptime
    name: Male Washroom Uptime
    update_interval: 10s
  - platform: wifi_signal
    name: Male Washroom  RSSI
    update_interval: 5s
    icon: mdi:memory
    name: Male Washroom ESP Free Memory
    lambda: return heap_caps_get_free_size(MALLOC_CAP_INTERNAL) / 1024;
    unit_of_measurement: 'kB'
    state_class: measurement
time:
  - platform: sntp
switch:
  - platform: ld2410
    engineering_mode:
    bluetooth:
      name: Control Bluetooth
  - platform: gpio
    name: Male Washroom relay
    pin: 18
button:
  - platform: ld2410
    factory_reset:
    restart:
    query_params:
  - platform: restart
    icon: mdi:power-cycle
text_sensor:
  - platform: ld2410
    version:
    mac_address:
i want to turn on on switch: male_washroom_relay if ld2410 detected presence or movement and turn it off if not detected anything
I don’t have one of these to test (on order…) but something like this should turn on the relay when presence detected, then turn off the relay 6 seconds after no presence detected.
binary_sensor:
  - platform: ld2410
    has_target:
      filters:
         - delayed_off: 6s
      on_press:
        then:
          - switch.turn_on: male_washroom_relay
      on_release:
        then:
          - switch.turn_off: male_washroom_relay
thanks for replaying but with this code i got an error, i want any one out of three conditions comes true male_washroom_relay turn on. its works but problem is when any one out of these three stop detection it turn of switch
i need the same to do in esphome! any suggestions?
