Hi all
I am trying for first time to add an esp32 in HA to test some temperature sensors. I added the ESPHome addon and I am trying to add the esp32 configuration. I am at the very begging of the process, and the main problem is that it doesn’t find my network. it finds only one that is not mine
What can I do about it?
It will not auto populate your wifi ssid’s. Just enter just enter the name and password for the network you want it to use.
ok, I just wrote my ssid and continue. (it worked)
Lol,
Basically you are telling the espmodule that after it was flashed, it should start up and connect to the specified wifi network.
The step you are showing is just to generate the yaml file before flashing…
