ESPHome: How to do measurements without connection to wifi:
Hello, may I ask for help please? I have following script: it takes measurement from BME280, connects to wifi, sends values over MQTT and then goes to sleep for 1 minute.
I would like to modify the script in the way it takes measurement every minute, but connects to wifi and sends value only if the temperature is over 26C. Or with binary sensor like in mailbox - to connect to wifi only if it detects that GPIO state changes. Is there anyone who understands how to do it please?
esphome:
  platform: ESP8266
  board: d1_mini_pro
wifi:
  ssid: "IoT"
  password: "98569856"
  ap:
    ssid: "MQTT test Fallback Hotspot"
    password: ""
  fast_connect: on
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
#api:
ota:
i2c:
  sda: 4
  scl: 5
  scan: True
  - platform: bme280
    i2c_id: bus_a
    temperature:
      name: "Bedroom Temperature"
      oversampling: 16x
    pressure:
      name: "Bedroom Pressure"
    humidity:
      name: "Bedroom Humidity"
    address: 0x76
    update_interval: 60s
deep_sleep:
  run_duration: 2s
  sleep_duration: 1min
mqtt:
  broker: 10.0.0.54
  username: janb
  password: janb12
  birth_message:
    topic: mqtt_test/status
    payload:
  will_message:
    payload:
  on_message:
    - topic: mqtt_test/ota_mode
      payload: 'ON'
      then:
        - deep_sleep.prevent: deep_sleep_1
    - topic: mqtt_test/sleep_mode
      payload: 'ON'
      then:
        - deep_sleep.enter: deep_sleep_1
Something like
    on_value_range:
      - above: 28
        then:
          connect to wifi, connect to mqtt and exchange messages
