Good time of day. I try to connect the I2C 1602 screen but it gives an error when compiling. Be advised that you may not have done so?
Code
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: $ssid
password: $password
fast_connect: True
Enable logging
logger:
Enable Home Assistant API
api:
password: ‘#########’
ota:
password: ‘##########’
i2c:
sda: D2
scl: D1
display:
- platform: lcd_pcf8574
dimensions: 16x2
address: 0x27
lambda: | -
it.print(“Hello World!”);
binary_sensor:
platform: status
dallas: -
pin: 12
update_interval: 60s -
pin: 13
update_interval: 58s
sensor: -
platform: dallas
address: 0xE20416B31F39FF28
name: “OPEN sensor” -
platform: dallas
address: 0xC20114403CD9AA28
name: “CLOSE sensor” -
platform: uptime
name: $hostname Uptime Sensor -
platform: dht
pin: D2
model: DHT22
temperature:
name: “Kitchen Temperature”
humidity:
name: “Kitchen Humidity”
update_interval: 10s
switch:
- platform: restart
name: “kitchen modul Restart”
error
INFO Reading configuration /config/esphome/kitchen.yaml…
ERROR Error while reading config: Invalid YAML syntax:
while parsing a block collection
in “/config/esphome/kitchen.yaml”, line 29, column 3:
expected , but found ‘’
in “/config/esphome/kitchen.yaml”, line 30, column 5:
dimensions: 16x2
