I recently installed ESPHome and I am having a real hard time getting my first ESP off the ground in ESPHome. I run Home Assistant Core (Hassio) in docker. I am using the Hassio add-on.
I bought this to use: https://smile.amazon.com/gp/product/B07QCP2451/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
The error I get is:
ERROR Connecting to X.X.X.44:3232 failed: [Errno 111] Connection refused
(the "X"s are just obscuring my subnet)
I have tried it without setting a static then I get:
INFO Successfully compiled program.
INFO Resolving IP address of esp_humidor.local
INFO Address in use when adding 169.254.104.237 to multicast group, it is expected to happen on some systems
INFO Address in use when adding 172.17.0.1 to multicast group, it is expected to happen on some systems
ERROR Error resolving IP address of esp_humidor.local. Is it connected to WiFi?
ERROR (If this error persists, please set a static IP address: https://esphome.io/components/wifi.html#manual-ips)
ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname
Not sure what to do to clear this up.
Here is the current config I am trying I have also tried it as a ESP32s NodeMCU board but the result was the same.
esphome:
platform: ESP32
board: esp-wrover-kit
wifi:
ssid: "<SSID>"
password: "<password>"
fast_connect: true
# Optional manual IP
# manual_ip:
# static_ip: X.X.X.44
# gateway: X.X.X.1
# subnet: 255.255.255.0
ap:
ssid: "Esp Humidor Fallback Hotspot"
password: "<the autogenerated one>"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
esp32_ble_tracker:
- platform: xiaomi_lywsdcgq
mac_address: 58:2d:34:39:82:87
temperature:
name: "Humidor Temperature"
humidity:
name: "Humidor Humidity"
battery_level:
name: "Humidor Battery Level"
