Hello to all and TIA. I purchased some Xiaomi Mijiia bluetooth thermometers to install in some remote areas of my home. I flashed these using this link:https://pvvx.github.io/ATC_MiThermometer/TelinkMiFlasher.html and HA bluetooth picked them up instantly. I purchased a few Atom Lite ESP kits to extend my BT range. I have watched countless videos on how to install these, read many articles and I’ve had varying degrees of success. The latest method used was to follow this [link]
Currently, I have 2 proxies installed and working fine reading two BT remote thermometers. My issue is that I can’t “adopt” them. In the integration page I can see them but can’t visit them.
As soon as I attempt to install them, they will go offline and I get this:
At this point I have to go unplug the nodes and plug them into my laptop or my HA dedicated server and try again. I believe it can’t find my wifi network at this point despite being properly configured. Log:
`[D][wifi:386]: Starting scan…
[D][esp-idf:000]: W (10645) wifi:
[D][esp-idf:000]: Error! Should use default active scan time parameter for WiFi scan when Bluetooth is enabled!!!
[D][esp-idf:000]:
[D][wifi:401]: Found networks:
[D][wifi:450]: - ‘RazeWorld-Guest’[redacted] (BE:39:56:6D:B4:2B) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (BA:39:56:6D:B4:2B) [redacted]▂▄▆█
[D][wifi:450]: - ‘RazeWorld’[redacted] (B6:39:56:6D:B4:2B) [redacted]▂▄▆█
[D][wifi:450]: - ‘RazeWorld’[redacted] (B6:39:56:6D:D6:9A) [redacted]▂▄▆█
[D][wifi:450]: - ‘RazeWorld-Guest’[redacted] (BE:39:56:6D:D6:9A) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (BA:39:56:6D:D6:9A) [redacted]▂▄▆█
[D][wifi:450]: - ‘RazeWorld-Guest’[redacted] (BE:39:56:6D:E4:32) [redacted]▂▄▆█
[D][wifi:450]: - ‘RazeWorld’[redacted] (B6:39:56:6D:E4:32) [redacted]▂▄▆█
[D][wifi:450]: - ‘725E’[redacted] (98:52:4A:70:8E:85) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (98:52:4A:70:8E:86) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (DC:EB:69:F1:50:0C) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (DC:EB:69:F1:50:0A) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (98:52:4A:70:8E:88) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (98:52:4A:70:8E:8A) [redacted]▂▄▆█
[D][wifi:450]: - ‘home’[redacted] (DC:EB:69:F1:50:07) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (DC:EB:69:F1:50:0D) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (26:60:F9:EE:28:95) [redacted]▂▄▆█
[D][wifi:450]: - ‘home deco’[redacted] (AC:15:A2:6A:3D:82) [redacted]▂▄▆█
[D][wifi:450]: - ‘home deco’[redacted] (2E:60:F9:EE:28:98) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (F6:A9:40:58:02:03) [redacted]▂▄▆█
[D][wifi:450]: - ‘BRHOMEWIFI_GUEST’[redacted] (18:31:BF:5E:15:31) [redacted]▂▄▆█
[D][wifi:450]: - ‘HP-Print-6F-Photosmart 7520’[redacted] (2C:44:FD:60:F5:6F) [redacted]▂▄▆█
[W][wifi:455]: No matching network found!
[D][esp-idf:000]: W (19220) wifi:
[D][esp-idf:000]:
[D][wifi:450]: - ‘home deco’[redacted] (26:60:F9:EE:28:96) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (B2:15:A2:6A:3D:82) [redacted]▂▄▆█
[D][wifi:450]: - ‘’[redacted] (2E:60:F9:EE:28:9F) [redacted]▂▄▆█
[D][wifi:450]: - ‘BRHOMEWIFI’[redacted] (18:31:BF:5E:15:30) [redacted]▂▄▆█
[D][wifi:450]: - ‘MOTODD0A’[redacted] (F8:CF:C5:FA:29:FE) [redacted]▂▄▆█
[D][wifi:450]: - ‘Summarell’[redacted] (EC:A9:40:58:02:03) [redacted]▂▄▆█
[D][wifi:450]: - ‘RANGEXTend 1’[redacted] (00:E0:20:23:BE:91) [redacted]▂▄▆█
[D][wifi:450]: - ‘ATTaYJsNI2-EXT-EXT’[redacted] (00:E0:20:24:D2:19) [redacted]▂▄▆█
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 188777542, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:6656
load:0x40078000,len:14848
load:0x40080400,len:3792
entry 0x40080694
I (27) boot: ESP-IDF 4.4.2 2nd stage bootloader
I (27) boot: compile time 01:46:54
I (27) boot: chip revision: 1
I (30) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (37) boot.esp32: SPI Speed : 40MHz
I (42) boot.esp32: SPI Mode : DIO
I (46) boot.esp32: SPI Flash Size : 4MB
I (51) boot: Enabling RNG early entropy source…
I (56) boot: Partition Table:
I (60) boot: ## Label Usage Type ST Offset Length
I (67) boot: 0 otadata OTA data 01 00 00009000 00002000
I (74) boot: 1 phy_init RF data 01 01 0000b000 00001000
I (82) boot: 2 app0 OTA app 00 10 00010000 001c0000
I (89) boot: 3 app1 OTA app 00 11 001d0000 001c0000
I (97) boot: 4 nvs WiFi data 01 02 00390000 0006d000
I (104) boot: End of partition table
I (109) boot_comm: chip revision: 1, min. application chip revision: 0
I (116) esp_image: segment 0: paddr=001d0020 vaddr=3f400020 size=3372ch (210732) map
I (201) esp_image: segment 1: paddr=00203754 vaddr=3ffbdb60 size=05308h ( 21256) load
I (209) esp_image: segment 2: paddr=00208a64 vaddr=40080000 size=075b4h ( 30132) load
I (222) esp_image: segment 3: paddr=00210020 vaddr=400d0020 size=e08a4h (919716) map
I (555) esp_image: segment 4: paddr=002f08cc vaddr=400875b4 size=1552ch ( 87340) load
I (591) esp_image: segment 5: paddr=00305e00 vaddr=50000000 size=00010h ( 16) load
I (605) boot: Loaded app from partition at offset 0x1d0000
I (605) boot: Disabling RNG early entropy source…
I (617) cpu_start: Pro cpu up.
I (617) cpu_start: Starting app cpu, entry point is 0x4008223c
I (0) cpu_start: App cpu up.
I (633) cpu_start: Pro cpu start user code
I (634) cpu_start: cpu freq: 160000000
I (634) cpu_start: Application information:
I (638) cpu_start: Project name: atom-bluetooth-proxy-a78e40
I (645) cpu_start: App version: 2023.2.1
I (650) cpu_start: Compile time: Feb 16 2023 15:13:08
I (656) cpu_start: ELF file SHA256: 997c06b740a904c7…
I (662) cpu_start: ESP-IDF: 4.4.2
I (667) heap_init: Initializing. RAM available for dynamic allocation:
I (674) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (680) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
I (686) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
I (692) heap_init: At 3FFCB0B8 len 00014F48 (83 KiB): DRAM
I (698) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (705) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (711) heap_init: At 4009CAE0 len 00003520 (13 KiB): IRAM
I (718) spi_flash: detected chip: gd
I (722) spi_flash: flash io: dio
I (727) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.`
Sorry if I didn’t post this correctly, despite using HA for a year nothing comes easily to me. They work fine until adoption. I configured them as generic ESP32 units and could communicate with them just fine, but they were not seeing the BT devices.
