I understand this might not the right community to address Linux related questions.
However I just moved to Linux for the first time in my life from Windows and and it is more difficult than I thought.
I am a Home Assistant user and trying to rebuild the same tools that I have on Windows.
I use ESPHOME and I wanted to install esphomeflasher. I installed python first then I am entering the following to install esphomeflasher: `
pip3 install esphomeflasher.
After a few seconds I get a bunch of red lines with the final following ones being:
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-e2gscsgq/wxpython/setup.py'"'"'; __file__='"'"'/tmp/pip-install-e2gscsgq/wxpython/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-fcjqmgmx/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/oem/.local/include/python3.8/wxpython Check the logs for full command output.
I just tried, but I understand that I can’t USB flash on my local machine and I have to use the USB on the Raspberry. Do I have an option to flash locally (my raspberry is not easily accessible )?
