Hello, folks! I’ve automated my A/C unit and I’ve made the code available for all of you who have similar units to go through summer with maximum comfort and maximum power savings.
Here you go:
FUST Novamatic CL 1590 for ESPHome
This project integrates a Novamatic CL 1590 portable mini-split
air conditioning unit, through its infrared port and a small
ESP8285 microcontroller with infrared transmitter on board
(typically board type esp01_m
on ESPHome). It supports all
modes and temperature targets of the air conditioner unit.
Will this work with my A/C unit?
The remote control this climate component simulates is model
number AR-715 (parts code IR30-0168CN—B), so check your
A/C unit’s remote — if it matches, this is for you: you got
yourself a smart A/C unit now.
Will this work with my ESP device?
Probably, so long as it has an infrared transmitter that can
do 38 KHz.
This is the unit I got.
It works perfectly with the code as it ships.
If your transmitter doesn’t do 38 KHz by default, you may have
to adjust the code to change the default frequency of your unit,
as the code does not do this currently. Right after
auto *data = transmit.get_data();
in novamatic_climate.cpp
you may add data->set_carrier_frequency(38000);
to achieve
that effect.
How do I program the circuit?
Use your own version of this sample ESPHome sketch:
esphome:
friendly_name: IR transceiver
external_components:
- source:
type: git
url: https://github.com/Rudd-O/novamatic_climate
ref: master
components:
- novamatic_climate
esp8266:
# ESP8285 IR transceiver
board: esp01_1m
# Enable logging
logger:
level: debug
# Enable Home Assistant API
api:
encryption:
key: !secret api_key
services:
- service: send_pronto
variables:
data: string
then:
- remote_transmitter.transmit_pronto:
data: !lambda 'return data;'
ota:
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
button:
- platform: restart
entity_category: diagnostic
icon: mdi:restart
- platform: safe_mode
name: Safe mode restart
icon: mdi:restart-alert
climate:
- platform: novamatic_climate
name: Novamatic CL 1590
supports_heat: false
transmitter_id: transmitter
icon: mdi:air-conditioner
remote_receiver:
pin:
number: GPIO14
inverted: True
dump: pronto
remote_transmitter:
pin: GPIO4
carrier_duty_percent: 50%
- platform: wifi_signal
name: "Wi-Fi signal strength"
update_interval: 10s
entity_category: "diagnostic"
