ESPHome IR Blaster (NAS-IR02W6-Pro V3) / Stbility Problems
I have had really good luck flashing ESPHome into Tuya Beken BK7231T IR Blasters. There were no Sub-G radios in these IR Blasters.
However, I have had nothing but stability problems with another set of Tuya Beken BK7231N IR Blasters which have built in Sub-G radios (Tuya SH4) connected to the BK7231N. The PCB of this IR Blaster has this written in its silkscreen: “NAS-IR02W6-Pro V3 2022.05.17”
I am using HAOS to monitor / maintain the IR Blasters. I wrote different YAML files for each kind of IR Blasters. I changed the processor type and some of the GPIO pin assignments.
I fear that since I am not including anything in my YAML files for the Sub-G radios, that random data from the radios are causing the IR Blaster to randomly disconnect and reconnect from/to the WIFI.
Has anyone gotten Tuya IR Blasters using Beken BK7231N processors connected to Sub-G (SH4) radio stably working with ESPHome?
The specifications for the SH4 radio (the castellated daughter board above) can be found here.
