I have some Genio IR devices flashed with ESPhome which are working well to send IR signals to the ceiling fans I have. What I am trying to do is use the switch templates I’ve created to create a fan entity in home assistant so this works natively, with all code on the ESPHome. I’m sure it’s possible but I think I’m missing something, probably simple.
This is part of the code I’ve got for the switch. Then I have switches for Med and High.
remote_transmitter:
pin: GPIO14
carrier_duty_percent: 50%
remote_receiver:
pin:
number: GPIO5
inverted: True
# dump: raw
switch:
turn_on_action:
remote_transmitter.transmit_raw:
code: [1238, -438, 1238, -439, 340, -1272, 1239, -438, 1239, -438, 1239, -439, 340, -1274, 340, -1273, 340, -1272, 1239, -438, 1240, -439, 340, -7436, 1238, -438, 1239, -439, 340, -1273, 1239, -438, 1240, -438, 1240, -439, 340, -1275, 340, -1273, 340, -1273, 1240, -437, 1240, -439, 340, -7263, 1239, -437, 1240, -439, 340, -1274, 1240, -438, 1240, -438, 1240, -440, 340, -1275, 340, -1274, 340, -1274, 1239, -438, 1240, -440, 340, -7242, 1239, -438, 1240, -439, 340, -1274, 1240, -438, 1240, -439, 1240, -440, 340, -1275, 340, -1275, 340, -1273, 1240, -438, 1240, -440, 340, -7266, 1238, -439, 1239, -440, 339, -1275, 1239, -440, 1239, -439, 1240, -440, 340, -1276, 339, -1276, 339, -1274, 1239, -439, 1240, -440, 339, -7246, 1238, -440, 1239, -440, 339, -1276, 1239, -439, 1239, -440, 1240, -441, 339, -1276, 339, -1277, 339, -1274, 1239, -440, 1239, -441, 339, -7574, 1238, -440, 1239, -441, 338, -1276, 1239, -440, 1239, -441, 1239, -441, 339, -1277, 339, -1277, 338, -1276, 1238, -440, 1239, -441, 339, -7452, 1238, -440, 1239, -441, 339, -1276, 1238, -441, 1239, -440, 1240, -441, 338, -1278, 338, -1277, 339, -1275, 1239, -441, 1238, -442, 338]
carrier_frequency: 38kHz
turn_on_action:
code: [1239, -438, 1239, -439, 339, -1273, 1239, -438, 1239, -439, 340, -1274, 340, -1272, 1240, -438, 340, -1274, 340, -1273, 340, -1273, 340, -7280, 1239, -438, 1240, -438, 340, -1273, 1240, -438, 1240, -439, 340, -1275, 340, -1273, 1239, -439, 340, -1275, 340, -1274, 340, -1273, 341, -7348, 1239, -438, 1240, -438, 341, -1273, 1240, -438, 1240, -439, 341, -1274, 341, -1273, 1240, -439, 340, -1274, 341, -1274, 340, -1273, 341, -7349, 1239, -438, 1240, -439, 340, -1274, 1240, -438, 1240, -439, 340, -1275, 341, -1273, 1240, -439, 340, -1275, 340, -1274, 340, -1274, 340, -7351, 1239, -439, 1239, -440, 340, -1274, 1240, -439, 1240, -440, 339, -1276, 340, -1274, 1240, -440, 339, -1276, 339, -1275, 340, -1275, 340, -7330, 1238, -439, 1239, -440, 340, -1274, 1240, -439, 1240, -440, 339, -1276, 340, -1274, 1240, -440, 339, -1276, 339, -1276, 340, -1274, 340, -7658, 1239, -439, 1239, -441, 339, -1275, 1239, -439, 1240, -441, 339, -1276, 340, -1274, 1239, -441, 339, -1277, 339, -1276, 339, -1275, 340, -7294, 1238, -439, 1239, -441, 339, -1276, 1239, -440, 1239, -441, 339, -1277, 339, -1275, 1239, -441, 339, -1276, 339, -1276, 339, -1276, 339]
