I use esphome+esp8266 to send infrared remote control signal, to control the temperature of electric water heater,
The machine is an ARISTON water heater (ARTES MED series). I don’t know the specific model.
I try to capture the IR code:
remote_receiver:
pin:
number: GPIO14
inverted: True
mode: INPUT_PULLUP
dump: all
short press:
[17:07:28][I][remote.jvc:049]: Received JVC: data=0x00F3
[17:07:28][I][remote.lg:054]: Received LG: data=0x00F36996, nbits=32
[17:07:28][I][remote.nec:097]: Received NEC: address=0xCF00, command=0x6996 command_repeats=1
[17:07:28][I][remote.pronto:233]: Received Pronto: data=
[17:07:28][I][remote.pronto:235]: 0000 006D 0022 0000 015E 00AD 0017 0015 0017 0015 0016 0015 0017 0015 0017 0015 0016 0015 0017 0015 0017 0015 0016 0041 0017 0040 0017 0041 0016 0042 0016 0015 0016 0015 0017 0041 0016 0042 0016 0015 0016 0042 0016 0040 0017 0016
[17:07:28][I][remote.pronto:235]: 0016 0040 0017 0016 0016 0015 0016 0042 0016 0041 0016 0016 0016 0016 0015 0042 0016 0016 0015 0042 0016 0041 0016 0016 0016 0181 06C3
[17:07:28][W][component:214]: Component remote_receiver took a long time for an operation (0.05 s).
[17:07:28][W][component:215]: Components should block for at most 20-30ms.
[17:07:28][I][remote.pronto:235]: 0000 006D 0002 0000 015D 0056 0017 0181 06C3
long press for 5 seconds:
[17:08:25][I][remote.jvc:049]: Received JVC: data=0x00F3
[17:08:25][I][remote.lg:054]: Received LG: data=0x00F36996, nbits=32
[17:08:25][I][remote.nec:097]: Received NEC: address=0xCF00, command=0x6996 command_repeats=1
[17:08:25][I][remote.pronto:233]: Received Pronto: data=
[17:08:25][I][remote.pronto:235]: 0000 006D 0022 0000 015D 00AD 0017 0015 0017 0015 0016 0015 0017 0015 0017 0015 0016 0015 0017 0015 0017 0015 0016 0041 0017 0040 0017 0041 0016 0041 0017 0015 0016 0015 0017 0041 0016 0041 0017 0015 0016 0041 0017 0040 0017 0015
[17:08:25][I][remote.pronto:235]: 0017 0040 0017 0015 0017 0015 0016 0041 0017 0040 0017 0015 0017 0015 0016 0042 0016 0015 0016 0041 0017 0041 0016 0016 0016 0181 06C3
[17:08:25][W][component:214]: Component remote_receiver took a long time for an operation (0.05 s).
[17:08:25][W][component:215]: Components should block for at most 20-30ms.
[17:08:25][I][remote.pronto:235]: 0000 006D 0002 0000 015D 0056 0017 0181 06C3
[17:08:26][I][remote.pronto:233]: Received Pronto: data=
[17:08:26][I][remote.pronto:235]: 0000 006D 0002 0000 015D 0056 0017 0181 06C3
[17:08:27][I][remote.pronto:235]: 0000 006D 0002 0000 015D 0056 0017 0181 06C3
[17:08:27][I][remote.pronto:233]: Received Pronto: data=
[17:08:28][I][remote.pronto:233]: Received Pronto: data=
[17:08:28][I][remote.pronto:235]: 0000 006D 0002 0000 015D 0056 0017 0181 06C3
I use this code to send IR signal:
switch:
turn_on_action:
- remote_transmitter.transmit_nec:
address: 0xCF00
command: 0x6996
command_repeats: 1
But how can I send the “long-press” signal? Not multiple clicks.
update:
I found NEC Infrared Transmission Protocol ( https://techdocs.altium.com/display/FPGA/NEC+Infrared+Transmission+Protocol ), It explains how to deal with “If the key on the remote controller is kept depressed”, but I don’t know how to do this on esphome.
update:
Thanks everyone’s replys. I’m a beginner and I still can’t solve this problem in esphome, but I found it is very easy to do in Tasmota, just one command:
IRSend {"Protocol":"NEC","Bits":32,"Data":0xF36996,"Repeat":50}
or
IRSend50 {"Protocol":"NEC","Bits":32,"Data":0xF36996}
But I still wat to do it in esphome, and I will continue to look for ways.
