I’ve just published an ESPHome project I’ve been working on to Github.
The intention was to learn about ESPHome rather than being “really necessary”, I mean this could be done pretty simply in Home Assistant.
I’ve called it Iron Timer as it’s designed to turn off your clothes iron after a countdown time selected with a rotary encoder and displayed on a LED display. It’s pretty lambda heavy so might help if that’s your thing. Check it out! https://github.com/patfelst/Iron-Timer-Mk2.
The ugly prototype:
and a block diagram / circuit diagram
The ESPHome yaml config is 290 odd SLOC, you can find it here. Here’s a snapshot of the display code:
display:
- platform: lcd_ht16k33
address: 0x70
update_interval: 1s
scroll: true
scroll_speed: 200ms
scroll_dwell: 10s
scroll_delay: 5.0
lambda: |-
int encoder = 0;
int mins = 0;
int secs = 0;
//ESP_LOGW("display", "Mode = %d", id(rotary_encoder_mode));
switch (id(rotary_encoder_mode)) {
case SET_TIMER_MODE:
encoder = (int) (id(knob).state * 15.0); // Display in 15 second increments
// Set countdown timer - just display, don't countdown
secs = encoder % 60;
mins = (encoder - secs) / 60;
if (encoder > 0)
it.printf("%2d.%02d", mins, secs);
break;
case COUNTDOWN_MODE:
if (id(countdown) > 0 ) {
id(countdown)--;
secs = id(countdown) % 60;
mins = (id(countdown) - secs) / 60;
if (!id(shutdown_early))
else {
// Put an asterix in the first digit as another cue to the user that they requested an immediate end to the countdown
it.printf("*%1d.%02d", mins, secs);
break;
case SET_BRIGHTNESS_MODE:
it.set_brightness(id(led_brightness));
it.printf("Brightness %.1f", id(led_brightness));
break;
case BOOT_MSG_MODE:
// This message gets displayed once for 5 seconds after power on
static int boot_timer = 0;
if (boot_timer <= 5) {
boot_timer++;
it.printf("%s", "Iron Timer");
else {
id(rotary_encoder_mode) = SET_TIMER_MODE;
break;
I hope you find this useful, or at least interesting!
