Hi, I have a problem with a nodemcu which works fine usually, but sometimes (not sure what happens) my configured switch is not working. After I reboot (unplug and plug again the nodemcu) all is fine.
Since I am not able to figure out which is the problem, I wish to have the ability to restart/reboot the nodemcu from HASS.
Thanks I just saw that, and included in the configuration. This is a restart of the (software) node, and/or a reboot of the nodemcu (or is it the same thing)?
Anyway I will see if the platform: restart will solve my current problem.
it might be the power supply (not sure what else can be). I have it plugged to a 2,1A power supply, I do not have other to try. Just ordered a 3A type will try those when they arrive (1 month âŚ)
Since I added the restart switch, I havenât needed it, but I did try it on one of my nodemcuâs and according to the Uptime sensor it restarted the device.
Also I was assuming that you would be unable to issue commands if your switch stops responding. The sleep regular reset method should work in this case (like a watchdog timer).
No âheapsâ does not mean âenoughâ, âheapsâ informally means a lot more than enough. Look at the link I posted. Peak currents of less than 0.5A are required. You have 4 times that available.
For my application, a GPIO connected to a button through a 10K resistance a 1A power supply was not enough (tried and tested with a original Samsung 1A power supply).
Problem is many chinese power adapter are rated 2A and probably are 1A in reality, Now I bought a âratedâ 3A, hoping is at least 2A
Ah. As well as not being rated for the specified current many of the cheaper ones dont have very good filtering either. You get a lot of high frequency switching noise that can cause havoc.
Could you please update this thread if it works when you eventually need it. Iâm worried that the ESP hanged and wonât respond to the switch change. Thanks.
