Yeah I’m finding it difficult to get the logs out as they reset upon restarting the HA instance. After choosing the command to install manually, it does seem to be the compiling that’s killing the instance, which is odd as I’ve had it working on this device before I switched to an SSD. Below is the output of the compiling before it goes offline
INFO Reading configuration /config/esphome/living-room-plant.yaml...
INFO Generating C++ source...
INFO Compiling app...
INFO Running: platformio run -d /config/esphome/living-room-plant
Processing living-room-plant (board: esp01_1m; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
PACKAGES:
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
Library Manager: Installing Update
Library Manager: Already installed, built-in library
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
| |-- <ESP8266WiFi> 1.0
|-- <ESPAsyncWebServer-esphome> 1.2.7
| |-- <Hash> 1.0
|-- <ESP8266mDNS> 1.2
|-- <DNSServer> 1.1.1
Compiling /data/living-room-plant/.pioenvs/living-room-plant/lib768/ESPAsyncWebServer-esphome/SPIFFSEditor.cpp.o
Compiling /data/living-room-plant/.pioenvs/living-room-plant/lib768/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling /data/living-room-plant/.pioenvs/living-room-plant/lib768/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling /data/living-room-plant/.pioenvs/living-room-plant/lib768/ESPAsyncWebServer-esphome/WebResponses.cpp.o
