Hi All,
I am working on integrating ESPhome into the new Energy feature and need to return a positive from one CT clamp that shows both positive and negative values. Positive is when i am buying power from the grid and negative when i am selling it.
I have defined 2 platform templates as below
#Total House Watts draw
name: ${disp_name} Total House Watts draw
lambda: !lambda |-
if (id(HouseWatts) > 1) {
// global value is greater than 5
return id(HouseWatts) * 1;
} else {
return id(HouseWatts) * 0;
accuracy_decimals: 1
unit_of_measurement: W
icon: "mdi:flash-circle"
update_interval: ${update_time}
#Total House Watts return
name: ${disp_name} Total House Watts return
lambda: !lambda |-
if (id(HouseWatts) < 1) {
// global value is greater than 1
return id(HouseWatts) * -1;
// convert negitave number into positive
} else {
/config/energy-monitor.yaml: In lambda function:
/config/energy-monitor.yaml:162:24: error: ISO C++ forbids comparison between pointer and integer [-fpermissive]
/config/energy-monitor.yaml:164:28: error: invalid operands of types 'esphome::sensor::Sensor*' and 'int' to binary 'operator*'
/config/energy-monitor.yaml:166:29: error: invalid operands of types 'esphome::sensor::Sensor*' and 'int' to binary 'operator*'
*** [.pioenvs/energy-monitor/src/main.cpp.o] Error 1
========================== [FAILED] Took 2.18 seconds ==========================
As below but the conditional lambda if then does not work with errors about the variable type
Please help
Lachlan
