ESPHome Lamda hh:mm
I have a modbus sensor that returns time in 24H format as an integer [0000 2359]. So 09:00 will be returned as 900, 23:45 would be returned as 2345, 01:30 returned as 130. You get the idea. I want to write a lambda function to return the time in the format hh:mm. This is as far as I’ve got but I dont know how to output the string value.
 - platform: modbus_controller
   modbus_controller_id: inverter
   name: "Setting Timezone2"
   register_type: holding
   skip_updates: ${settings_skipped_updates}
   address: 251
   filters:
    - lambda: |-
           int minutes, hours;
           minutes = static_cast<int>(x) % 100;
           hours = static_cast<int>(x) / 100;
           return <what next>;
   icon: "mdi:clock"
I’ve created a template sensor in home assistant which does what I want but how to do this in ESPHome?
time_zone2:
     friendly_name: Program2
     value_template: >
       {% set time = {
       "hour": (states('sensor.setting_timezone2') |float(0) /100 ) | round(0),
       "minute": (states('sensor.setting_timezone2') |float(0) % 100 ) | round(0) }
       {{'{:02d}'.format(time.hour)}}:{{'{:02d}'.format(time.minute)}}
Update
I’ve manged to create a text sensor, that does this. Is there a better way?
text_sensor:
    lambda: |-
        int minutes, hours;
        minutes = static_cast<int>(id(setting_timezone2).state) % 100;
        hours = static_cast<int>(id(setting_timezone2).state) / 100;
        char formatted_time[6];
        snprintf(formatted_time, sizeof(formatted_time), "%02d:%02d", hours, minutes);
        return esphome::optional<std::string>(formatted_time);
