Hi guys,
Been playing around with my ESP32-BOX-S3 and trying to make a GIF animate on the screen without luck - not finding any good examples. I only get a static image (assume it is the first frame in the Gif).
Anybody know the solution?
Code tested (the rest of the code is redacted as I get a static image and ESP works in ESPHome):
animation:
- file: "woo-hoo-bender.gif"
resize: 320x240
type: RGB24
use_transparency: true
display:
- platform: ili9xxx
model: S3BOX
data_rate: 40MHz
cs_pin: 5
dc_pin: 4
reset_pin:
number: 48
inverted: true
update_interval: never
pages:
- id: idle_page
lambda: |-
id(bender_woohoo).next_frame();
it.image(0, 0, id(bender_woohoo), COLOR_ON, COLOR_OFF);
