With assistance from @pepe59, I managed to get several LD2410C Devices working around the house reporting both moving and still targets…until I installed a couple of LD2450 Devices. Now, the two LD2450 Devices are reporting properly but each of the LD2410C Devices report Unknown for everything.
Has anyone else encountered this? If so, how did you resolve the issue, please?
If not, has anyone any suggestions on the steps that I should take to attempt analysis of the cause, please?
I am also having problems with LD2410 but don’t have any LD2450’s.
You asked what you could try. First thing I would try is to take out the LD2450s from the integration to confirm your LD2410s start working again once the other ones are removed.
I’m having a similar issue except I don’t have any LD2450 devices and only some of my LD2410C devices are impact. It is weird. No clue what is going on yet. Same code on working and non-working devices. Started happening about a month ago or so. I even tried adding a new LD2410C device, same result. The device reports the sensors for the ESP32 board (temp, cpu, …) but the LD2410C reports “Unknown” for everything.
