I am trying to get a setup working where I can have a slider on the HA frontend to adjust the brightness of a LED Matrix in its range from 0-15 where 0 is the lowest brightness but not off and 15 the brightest. I have found a forum post that explains that with sensor for the brightness already working on a HA system as far as I understand it.
However I don not have a brightness sensor and I prefer using a slider as shown here:
I assume I have to create that entity 1st in HA where the slider changes a value between 0-15, I am not clear how I can do that. Ideally I like to implement that “on foot” in the configuration.yaml file rather than importing blueprints or such just to understand it in the most minimalistic way possible. Could anybody help me, I am not even sure what it would be called in HA lingo what I am looking for.
I have found “Input Numbers” which appears to be what I am looking for but I am still failing to make this work. In configuration.yaml I have the lollowing:
The LED Matrix will only set the brightness as its set in the intensity value in the display definition, not according to the value I set with the slider. I can see in the loghs the values are actually communicated to the ESPHome device. Any suggestion what I am doing wrong here ?
I was struggling with the same thing and seems it’s broken esphome max7219digit implementation but luckily there is simple workaroud: use intensity instead of set_intensity, like:
