ESPHome LED text notifier with basic response buttons
My wife and I work from home, due to the pandemic, and have frequent video meetings. Sometimes I have a quick question or request but don’t want to disrupt her meeting by knocking and she doesn’t always check her phone messages, so I came up with this solution.
She or I can send messages to the LED matrix in the home office via Home Assistant text input field which is displayed on the screen for 1 minute. Pressing the green, yellow, or red buttons will respond Yes/OK, Please wait, or No via TTS to the living room Nest Hub Max speaker as well as display that in text on the display.
This test was from the living room, from where the audio is playing, but the device will be installed in the office.
Components
  • NodeMCU running ESPHome (from Aliexpress)
  • 4-panel Max7219 Digit Display (from Aliexpress)
  • Arcade buttons (from a local electronics store)
  • Clear case (from a local dollar store)
The wiring is very simple, D0, D1, D2 go to the screen per the ESPHome documentation example and D5, D6, and D7 go to each button.
ESPHome yaml
esphome:
esp8266:
  board: nodemcu
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: <removed>
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Office-Text Fallback Hotspot"
    password: <removed>
captive_portal:
binary_sensor:
  - platform: gpio
    pin:
      number: D5
      inverted: true
      mode:
        input: true
        pullup: true
  - platform: gpio
    pin:
      number: D6
      inverted: true
      mode:
        input: true
        pullup: true
  - platform: gpio
    pin:
      number: D7
      inverted: true
      mode:
        input: true
        pullup: true
spi:
  clk_pin: D0
  mosi_pin: D1
display:
  - platform: max7219digit
    cs_pin: D2
    num_chips: 4
    intensity: 1
    scroll_speed: 70ms
    scroll_delay: 0ms
    lambda: |-
      if (id(office_text).has_state()) {
        it.printf(0, 0, id(digit_font), " %s ", id(office_text).state.c_str());
      } else {
        it.turn_on_off(true);
font:
  - id: digit_font
    file: "fonts/pixelmix.ttf"
    glyphs: '"/@&?!%()+=,-_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz'
text_sensor: # This helper input field entity needs to be created in HA
  - platform: homeassistant
    entity_id: input_text.office_text
Automation yaml
alias: Office text buttons
description: ''
  - platform: state
    entity_id: binary_sensor.office_text_green_button
    to: 'on'
  - platform: state
    entity_id: binary_sensor.office_text_yellow_button
    to: 'on'
  - platform: state
    entity_id: binary_sensor.office_text_red_button
    to: 'on'
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: input_text.set_value
              value: Yes/OK
          - service: tts.google_say
              entity_id: media_player.lr_hub
              message: Yes, OK
      - conditions:
        sequence:
              value: Please wait
              message: Please wait
      - conditions:
        sequence:
              value: 'No'
              message: 'No'
    default: []
  - delay:
      seconds: 5
      value: ''
mode: restart
Next plans
Rather than send the response to a speaker, it would be ideal to send an HA app notification back to the person who set the LED text. This should be possible with trigger.to_state.context.user_id but I just need to figure out the details.
I thought about using Telegram for both the initial message and response but don’t want to force my wife to install another app.
Thanks for sharing this project! This is exactly what i was looking for.
