ESPHOME light platform GPIO PCF8574 - problem
Hello.
I have that part of the yaml file
i2c:
  sda: D2
  scl: D1
  scan: True
pcf8574:
  - id: pcf_expander
    address: 0x38
light:
  - platform: gpio
    name: ${devicename} - left bulb
    pin:
     pcf8574: pcf_expander
     number: 4
     # One of INPUT, INPUT_PULLUP or OUTPUT
     mode: OUTPUT
     inverted: True
unfortunately gets a mistake
Failed config
light.gpio: [source bathroom.yaml:48]
  Platform not found: 'light.gpio'.
  platform: gpio
  name: wemos_bathroom - left bulb
  pin:
    number: 4
    mode: OUTPUT
    inverted: True
what I’m doing wrong
Using a non-existent light platform. There is no platform: gpio for light.
The allowable light platforms are: https://esphome.io/index.html#light-components.
Thank You for the quick reply.
It is a pity that you can not be as GPIO.
So I’ll have to change the icon
greetings
I’m not sure what you mean by that.
Just use a binary light and point it at a gpio output.
I wanted to get the lamp icon at the switch in HA. It seemed to me that the easiest way to do this is to change the “switch” to “lamp”. As a last resort I did it by adding the “icon” option
icon: "mdi: lightbulb".
It worked, but now there is another problem :), because when the light is ON, the color of the lamp does not change
Thank You - it works!
My configuration look’s like this:
output:
  - platform: gpio
    pin:
     number: 4
     mode: OUTPUT
     inverted: True
  - platform: gpio
    pin:
      number: 5
      mode: OUTPUT
      inverted: True
  - platform: gpio
    pin:
      number: 6
      mode: OUTPUT
      inverted: True
  - platform: gpio
    pin:
      number: 7
      mode: OUTPUT
      inverted: True
light:
  - platform: binary
    output: relay_1
  - platform: binary
    name: ${devicename} - right bulb
    output: relay_2
  - platform: binary
    name: ${devicename} - door bulb
    output: relay_3
  - platform: binary
    name: ${devicename} - window bulb
    output: relay_4
