After much googling I managed to create a custom component for receiving LoRa messages with my ESPHome receiver from a LoRa soil moisture sensor. It works and also I can see the entities in Home Assistant, however the ESPHome receiver restarts itself upon every second message, so after booting it receives without a problem, but on the second incoming message it restarts.
Here is the log after the first message:
[D][custom:049]: Packet received!
[D][text_sensor:064]: 'sensorID': Sending state 'ID011271'
[D][sensor:094]: 'humi': Sending state 100.00000 % with 1 decimals of accuracy
[D][sensor:094]: 'temp': Sending state 22.95000 °C with 1 decimals of accuracy
[D][sensor:094]: 'adc': Sending state 888.00000 with 0 decimals of accuracy
[D][sensor:094]: 'batt': Sending state 993.00000 V with 0 decimals of accuracy
And after the second message I get this over the serial monitor:
Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400891df PS : 0x00060730 A0 : 0x8015a315 A1 : 0x3ffb2690
A2 : 0x0000002f A3 : 0x3ffb275d A4 : 0x00000007 A5 : 0x0000002f
A6 : 0x00000049 A7 : 0x31373231 A8 : 0x00000000 A9 : 0x3ff44000
A10 : 0x0000001f A11 : 0x00000000 A12 : 0x00000019 A13 : 0x00000001
A14 : 0x00060720 A15 : 0x00000001 SAR : 0x00000007 EXCCAUSE: 0x0000001d
EXCVADDR: 0x0000002f LBEG : 0x4008921c LEND : 0x40089232 LCOUNT : 0xffffffff
Backtrace:0x400891dc:0x3ffb26900x4015a312:0x3ffb26a0 0x4015a3b1:0x3ffb26c0 0x4015a457:0x3ffb26e0 0x400da578:0x3ffb2710 0x400e04ca:0x3ffb2750 0x4016dcb9:0x3ffb2790 0x4016dd41:0x3ffb27b0 0x400dd994:0x3ffb27d0 0x400dfc9e:0x3ffb2800 0x400ec495:0x3ffb2820
ELF file SHA256: 0000000000000000
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13132
load:0x40080400,len:3036
entry 0x400805e4
So far no amount of googling helped me to solve the issue, apart from that I know that something “illegal” is happening.
As my programing skills are at their end at this, I kindly ask for support.
My custom component code is the following:
#include "esphome.h"
#include <SPI.h>
#include <LoRa.h>
#define LORA_RST 2
#define LORA_DIO0 35
#define LORA_CS 25
#define SPI_MOSI 13
#define SPI_MISO 12
#define SPI_SCK 14
namespace MyTextData {
TextSensor *sensorID = new TextSensor();
class MyTextSensor : public Component, public TextSensor {
public:
TextSensor *sensorID = MyTextData::sensorID;
class MyLoRaSensor : public Component, public Sensor {
public:
Sensor *temp = new Sensor();
Sensor *humi = new Sensor();
Sensor *adc = new Sensor();
Sensor *batt = new Sensor();
void setup() override {
SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI, LORA_CS);
LoRa.setPins(LORA_CS, LORA_RST, LORA_DIO0);
while (!LoRa.begin(866E6)) {
delay(500);
LoRa.setSyncWord(0xF3);
void loop() override {
int packetSize = LoRa.parsePacket();
if (packetSize) {
ESP_LOGD("custom", "Packet received!");
const int max_line_length = 80;
static char buffer[max_line_length];
static int pos = 0;
while (LoRa.available()) {
char incoming = LoRa.read();
buffer[pos++] = incoming;
MyTextData::sensorID->publish_state(strtok(buffer, ","));
strtok(NULL, ":");
humi->publish_state(atof(strtok(NULL, ",")));
strtok(NULL, ":");
temp->publish_state(atof(strtok(NULL, ",")));
strtok(NULL, ":");
adc->publish_state(atoi(strtok(NULL, ",")));
strtok(NULL, ":");
batt->publish_state(atoi(strtok(NULL, ",")));
And my ESPHome yaml is:
esphome:
friendly_name: LoRa
libraries:
- SPI
- sandeepmistry/LoRa@^0.8.0
includes:
- my_LoRa_sensor.h
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "****"
ota:
password: "*****"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Lora Fallback Hotspot"
password: "****"
captive_portal:
text_sensor:
- platform: custom
lambda: |-
auto textsensor = new MyTextSensor();
App.register_component(textsensor);
return {textsensor->sensorID};
text_sensors:
- name: sensorID
- platform: custom
lambda: |-
auto sensor = new MyLoRaSensor();
App.register_component(sensor);
return {sensor->temp, sensor->humi, sensor->adc, sensor->batt};
sensors:
- name: "temp"
unit_of_measurement: "°C"
accuracy_decimals: 1
- name: "humi"
unit_of_measurement: "%"
- name: "adc"
- name: "batt"
unit_of_measurement: V
Thank you.
