ESPHome MAX6675 Component problems - Solved
i hope you could help me or add some tips. I have some issues with MAX6675 component. I get always 0°C result from the breakout.
my hardware configuration:
  • esp32 doit devkit v1
  • max6675 breakout - about 4 years old from CN
  • pins:
    DO = 19;
    CS = 5;
    CLK = 23;
    I’ve checked this:
  • wiring ok
  • with Arduino IDE it works
  • with Platformio it works
  • with ESPhome it doesn’t work
  • MAX6675 library ver. 1.1.0 from Adafruit
    Part of my ESPHome yaml:
spi:
miso_pin: GPIO19
clk_pin: GPIO23
  • platform: max6675
    cs_pin: GPIO5
    update_interval: 30s
Thank you in advance!
G
Update #1 my whole yaml:
Tested versions: 1.14.5, 1.16.0-dev
esphome:
  platform: ESP32
  board: esp32doit-devkit-v1
wifi:
  ssid: "SSID"
  password: "PASSWORD"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "OTApass"
ota:
  password: "OTApass"
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: True
pcf8574:
- id: "pcf8574_hub_output"
  address: 0x20
  pcf8575: false
- id: "pcf8574_hub_input"
  address: 0x24
  pcf8575: false
switch:
- platform: gpio
  pin:
   pcf8574: pcf8574_hub_output
   number: 0
   mode: OUTPUT
   inverted: true
binary_sensor:
- platform: gpio
  pin:
   pcf8574: pcf8574_hub_input
   number: 0
   mode: INPUT
   inverted: true
- platform: gpio
  pin:
   number: 1
   mode: INPUT
   inverted: true
- platform: gpio
  pin:
   number: 2
   mode: INPUT
   inverted: true
- platform: gpio
  pin:
   number: 3
   mode: INPUT
   inverted: true
- platform: gpio
  pin:
   number: 4
   mode: INPUT
   inverted: true
- platform: gpio
  pin:
   number: 5
   mode: INPUT
   inverted: true
- platform: gpio
  pin:
   number: 6
   mode: INPUT
   inverted: true
- platform: gpio
  pin:
   number: 7
   mode: INPUT
   inverted: true
spi:
 miso_pin: GPIO19
 clk_pin: GPIO23
dallas:
- id: "dallas_hub_1"
  pin: GPIO15
- platform: max6675
  spi_id: spi_max
  cs_pin: GPIO5
- platform: dallas
  address: 0xC7031554B6CCFF28
  dallas_id: dallas_hub_1
Update #2 - Problem solved
I’ve changed the wiring. MAX6675 CLK pin has been resoldered to pin 18. It’s the CLK pin of HW SPI of the board. The relevant SPI settings in config is this:
spi:
 miso_pin: GPIO19
 clk_pin: GPIO18
Please post your code ptoperly :slight_smile:
I used the example code from library:
https://github.com/adafruit/MAX6675-library/tree/master/examples/serialthermocouple
Can you post your ESPHome configuration properly formatted for us?
Point 11 here How to help us help you - or How to ask a good question
Thanks for the point. I"ve updated my post.
