Hi.
I have an ESP32 Wroom with MAX6675 Thermocouple.
This is my config:
- platform: max6675
cs_pin: GPIO15
update_interval: 10s
spi:
miso_pin: GPIO23
clk_pin: GPIO21
If I leave the CS wire connected in the GPIO15, the sensor always signals 0 degrees.
If I disconnect the CS wire from the ESP32 board, the sensor oscillates between 2, 64 and 66 degrees
What did i do wrong? Thanks
Not sure if it helps, but this guide usually helps me finding suitable pins: https://randomnerdtutorials.com/esp32-pinout-reference-gpios/
I have a thermocouple on an ESP32 working using the following pins and aligned with the VSPI bus:
spi:
clk_pin: GPIO18
miso_pin: GPIO19
- platform: max31855
cs_pin: GPIO5
I have tryed, but no results.
This is my ESP config:
esphome:
platform: ESP32
board: esp-wrover-kit
on_loop:
then:
- lambda: delay(5);
wifi:
ssid: "name"
password: "password "
power_save_mode: none
fast_connect: true
manual_ip:
static_ip: 192.168.1.30
gateway: 192.168.1.1
subnet: 255.255.255.0
logger:
api:
ota:
spi:
miso_pin: GPIO19
clk_pin: GPIO18
- platform: max6675
cs_pin: GPIO5
- platform: wifi_signal
update_interval: 60s
- platform: uptime
internal: true
text_sensor:
lambda: |-
uint32_t dur = id(uptime_s).state;
int dys = 0;
int hrs = 0;
int mnts = 0;
if (dur > 86399) {
dys = trunc(dur / 86400);
dur = dur - (dys * 86400);
if (dur > 3599) {
hrs = trunc(dur / 3600);
dur = dur - (hrs * 3600);
if (dur > 59) {
mnts = trunc(dur / 60);
dur = dur - (mnts * 60);
char buffer[17];
sprintf(buffer, "%ud %02uh %02um", dys, hrs, mnts);
return {buffer};
icon: mdi:clock-start
binary_sensor:
- platform: gpio
pin:
number: GPIO15
mode: INPUT_PULLUP
name: "Sensore Cancello"
device_class: opening
internal: false
