For now I have managed just to read info from SPF5000ES. It is connected to port usb-A.
This is the adapter used:
Hi.
Sorry for the late reply.
My config is:
substitutions:
devicename: "esphome-growatt-01"
upper_devicename: "ESPHome Growatt 01"
esphome:
esp8266:
board: esp07s
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
ota:
password: "fb53133b1e3dea138dfbbbee8d3e6653"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Growatt Fallback Hotspot"
password: "sR4TFWhJzHBT"
# Enable Web server
web_server:
port: 80
captive_portal:
time:
- platform: homeassistant
output:
# Blue Led
- id: light_bl
platform: gpio
pin: 16
# Green Led
- id: light_gr
platform: gpio
pin: 0
# Red Led
- id: light_rd
platform: gpio
pin: 2
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 115200
modbus:
uart_id: mod_bus
modbus_controller:
- id: growatt
## the Modbus device addr
address: 0x1
modbus_id: modbus1
setup_priority: -10
- platform: modbus_controller
name: "${devicename} DcPowerPV1"
address: 5
register_type: "read"
unit_of_measurement: W
device_class: power
icon: mdi:flash
value_type: U_DWORD
accuracy_decimals: 1
filters:
- multiply: 0.1
name: "${devicename} DcPowerPV2"
address: 10
device_class: power
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} DcVoltage"
address: 3
unit_of_measurement: V
device_class: voltage
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} DcInputCurrent"
address: 4
unit_of_measurement: A
device_class: current
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} AcFrequency"
address: 37
unit_of_measurement: Hz
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.01
name: "${devicename} AcVoltage"
address: 38
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} AcOutputCurrent"
address: 39
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
address: 40
device_class: power
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} EnergyToday"
address: 53
unit_of_measurement: kWh
device_class: energy
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} EnergyTotal"
address: 55
state_class: total_increasing
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Temperature"
address: 3093
unit_of_measurement: C
device_class: temperature
icon: mdi:thermometer
value_type: U_WORD
filters:
- multiply: 0.1
My history looks like this:
I really cant say what is causing this. -But my theory is that the inverter maybe switches between on-/offline a couple of times during the odd days which leads to an accumulating value? (My total production so far is only 97.4 kWh and my reading from the inverter seems correct and accumulating with no spikes).
17/12-22 EDIT: today it happended again. It seems to show exactly 4x the total production of my inverter when this occurs.
Manage to flash both my sticks S + X via VSCode with the PlatformIO plugin… The S was connected with a USB-TTL CP2102 converter, RX-TX needed NOT to be crossed and baudrate needed to be lowered to 115200.
Could not get them flashed with my MBPro M1, the device was found but timeout while flashing perhaps due to the USB-C to USB conversion? So I used a x86 Intel NUC with Ubuntu (again with VSCode) which worked fine. Both devices now show their graphs nicely when connecting to their IP.
I do have a question about the integration in HA, whenever I add the below to my configuration.yaml the configuration check hangs and it does not want to restart (I did not force it since it will probably not come up).
So am I missing some integration? some modbus support somewhere?
modbus:
uart_id: mod_bus
flow_control_pin: GPIO4
modbus_controller:
- id: growatt
address: 0x1
modbus_id: modbus1
setup_priority: -10
Would it be possible to re-flash the usb dongle, but still keep sending data to server.growatt.com?
That way the app still works. In case my home assistant hobby ends sooner than the inverter lifetime
(post deleted by author)
I’m having trouble setting the powerfactor. I’ve got all sensors working and can even read holding address 3 with the powerfactor but the code below does not work.
<code language== “YAML” >
number:
modbus_controller_id: growatt3000
name: “PV inverter Power factor Growatt 3000”
address: 0x3
value_type: U_WORD
lambda: "return x; "
write_lambda: |-
ESP_LOGD(“main”,“Modbus Number incoming value = %f”,x);
uint16_t powerfactor = x ;
payload.push_back(powerfactor);
return x;
I get this response:
[13:23:54][D][number:054]: ‘PV inverter Power factor Growatt 3000’ - Setting number value
[13:23:54][D][number:113]: New number value: 99.000000
[13:23:54][D][main:070]: Modbus Number incoming value = 99.000000
[13:23:54][D][number:012]: ‘PV inverter Power factor Growatt 3000’: Sending state 99.000000
[13:23:55][D][modbus_controller:029]: Modbus command to device=1 register=0x00 countdown=0 no response received - removed from send queue
[13:23:56][D][text_sensor:067]: ‘Growatt3300 Status’: Sending state ‘Unknown’
[13:24:10][D][modbus.number:023]: Number new state : 100.00
And the number value goes back to 100 percent. What do I do wrong?
First of all, thanks for all the hard work.
Question: I have a SPH-5000 inverter, connected to an SDM230-Modbus meter (connected by RJ45), in order to get house consumption data besides the production data. All the data us being sent by my Shine Wifi-S stick to growatt servers (with grott in the middle).
Using this method, will I be able to define sensors in ESPHome for all the data? I mean, not only for the production but also for the consumption data?
For anyone with SPH 10k-TL3 BH-UP here’s what worked for me for keeping the original USB stick and connections to the Growatt cloud and local updates every 10s. There are obviously far more values in the registers, I set up just what I was interested in…
HW:
ESP32
MAX3485 TTL/RS485
ESP32 pins tx/rx connected to the RS485 module, Pins 1 & 5 on the RS485-3 RJ-45 port on the inverter go to B & A on the RS485 module.
ESPHome config:
substitutions:
devicename: Growatt
esp_name: ESP Growatt #Device Name
update_fast: 10s
update_slow: 60s
esp_hostname: "esp-growatt"
ip_address: 192.168.5.104
ip_gw: 192.168.5.1
ip_netmask: 255.255.255.0
esphome:
esp32:
board: esp32dev
framework:
type: arduino
wifi:
manual_ip:
static_ip: ${ip_address}
gateway: ${ip_gw}
subnet: ${ip_netmask}
ap:
ssid: "${esp_name} Fallback Hotspot"
password: !secret ap_password
ota:
password: !secret ota_password
# Enable logging
logger:
baud_rate: 0
api:
encryption:
key: !secret api_key
captive_portal:
web_server:
port: 80
include_internal: true
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 9600
modbus:
uart_id: mod_bus
modbus_controller:
- id: growatt
address: 0x1
modbus_id: modbus1
update_interval: ${update_fast}
setup_priority: -10
button:
- platform: restart
# Setup for Growatt SPH 10k-TL3 BH-UP
name: "${devicename} Inverter Status"
address: 0
icon: mdi:home-lightning-bolt
value_type: U_WORD
name: "${devicename} Input Power"
address: 1
device_class: power
state_class: measurement
icon: mdi:solar-power-variant
value_type: U_WORD
accuracy_decimals: 0
filters:
- multiply: 0.1
name: "${devicename} PV1 Power"
address: 5
device_class: power
value_type: U_DWORD
internal: true
filters:
- multiply: 0.1
name: "${devicename} PV2 Power"
address: 9
device_class: power
value_type: U_DWORD
internal: true
filters:
- multiply: 0.1
name: "${devicename} PV Power"
device_class: power
lambda: |-
return float((id(pv1_power).state + id(pv2_power).state));
name: "${devicename} Output Power"
address: 35
device_class: power
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} PV1 Energy Today"
address: 59
value_type: U_DWORD
internal: true
filters:
- multiply: 0.1
name: "${devicename} PV1 Energy Total"
address: 61
value_type: U_DWORD
internal: true
filters:
- multiply: 0.1
name: "${devicename} PV2 Energy Today"
address: 63
value_type: U_DWORD
internal: true
filters:
- multiply: 0.1
name: "${devicename} PV2 Energy Total"
address: 65
value_type: U_DWORD
internal: true
filters:
- multiply: 0.1
name: "${devicename} PV Energy Today"
lambda: |-
return float((id(pv1_energy_today).state + id(pv2_energy_today).state));
update_interval: ${update_slow}
name: "${devicename} PV Energy Total"
lambda: |-
return float((id(pv1_energy_total).state + id(pv2_energy_total).state));
name: "${devicename} Inverter Temperature"
address: 93
unit_of_measurement: °C
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} Battery Discharging Power"
address: 1009
device_class: power
icon: mdi:battery-arrow-down
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Battery Charging Power"
address: 1011
device_class: power
icon: mdi:battery-arrow-up-outline
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Battery SoC"
address: 1014
unit_of_measurement: "%"
icon: mdi:home-battery
value_type: U_WORD
name: "${devicename} AC Power to User Total"
address: 1021
device_class: power
icon: mdi:transmission-tower-export
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} AC Power to Grid Total"
address: 1029
device_class: power
icon: mdi:transmission-tower-import
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} INV Power to Local Load Total"
address: 1037
device_class: power
icon: mdi:home-import-outline
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Battery Temperature"
address: 1040
value_type: U_WORD
filters:
- multiply: 0.1
name: "${devicename} Battery State"
address: 1041
value_type: U_WORD
name: "${devicename} Energy to User Today"
address: 1044
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Energy to User Total"
address: 1046
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Energy to Grid Today"
address: 1048
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Energy to Grid Total"
address: 1050
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Battery Discharge Today"
address: 1052
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Battery Discharge Total"
address: 1054
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Battery Charge Today"
address: 1056
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Battery Charge Total"
address: 1058
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Local Load Today"
address: 1060
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${devicename} Local Load Total"
address: 1062
value_type: U_DWORD
filters:
- multiply: 0.1
Hi Plawa,
I have an exact configuration as you do: 10k Growatt inverter, ESP32 board and MAX 485/TTL module. Tried your esphome code but there are no readings received from the inverter. I’am not sure about the pins - eventhough 1 and 5 are mentioned in the documentation, If I measure the voltage on these pins (connected to RS485-3 port on the inverter) there is only 15 mV but should be like 200 mV. Strange. Could you please check the RS485 settings one the invertor? It is under Basic parameters/RS485 Adr/COM Address, you can get to the settings menu by long press of the OK button next to inverter display? I have 001 there, not sure if this is the right value.
Attaching the screenshot with the log.
Any help or advise is appreciated.
Ahoj Pavle
I checked my inverter config, it’s set to 001, plus when I measure the voltage across the pins I’m using I get ~1.7V… from what I have read it can either be pin 1&5 or 4&5, see if that works for you.
Hodne stesti…
Hi Plawa, I tried pins 1&5 and 4&5, also tried two diffeent boards - ESP8266 and ESP32 with two different RS485/UART modules but with no success. Seems like there is no data coming from the RS485-3 connector. Maybe it must be enabled somewhere in the invertor settings but I have no clue of where to do it. Will investigate it a bit further. Thanks a lot. Pavel
Hi Plawa! I will like to see what model of RS 485 you have used. Can you post a picture with your setup?
Regarding HA Card, what card did you use? Is looking very nice. Thanks!
There is an on-screen menu for configuring the RS485. Hold down the OK button for a couple of seconds until it says “Basic Parameters”, and then you can navigate to RS485 settings. (SPH10000-TL3)
Hi Christoffer, yes, I am anware of this settings. We checked with Plawa in an offline communication that his settings is “unused” (other are ShineMaster, VPP and Meter2). For me having set “unused” does not help either. Will investigate furhter over the weekend but seems I am stuck with no ovious reason.
Hello there, im going to buy a SPH3600, i can see that you have export to grid information, is that provided by the GroWatt inverser or dou you use something else?
Hi, I got the first MAX3485 hit I got on Aliexpress (the red one with angled pins)…
The graph is just the custom mini graph lovelace card, nothing special
That is provided by my inverter but I can’t obviously guarantee it will be provided by yours…
hi.
This is the esphome code for Growatt SPF 5000 ES.
I’m using a d1 mini with a ttl converter.
This code allows changing the parameters of the inverter. BE CAREFUL !! (The worst thing that can happen is you have to configure the inverter again.)
The code has all the configurations that I was able to find, it doesn’t mean that they are all here.
The names are the factory names, I don’t change anything.
Thanks to all.
substitutions:
device_name: inv1
friendly_name: "inv1"
device_description: "Growatt SPF 5000 ES"
esphome:
comment: '${device_description}'
esp8266:
board: d1_mini
# Enable logging
logger:
baud_rate: 0
level: DEBUG
api:
encryption:
key: " your new api key " # https://esphome.io/components/api.html
ota:
safe_mode: true
reboot_timeout: 10min
num_attempts: 5
#web_server:
# port: 80
wifi:
reboot_timeout: 2min
# Optional manual IP
# ap:
# ssid: '${device_name}'
# password: !secret wifi_password
captive_portal:
time:
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 9600
#baud_rate: 115200
debug:
direction: RX
dummy_receiver: false
after:
delimiter: "\n"
- lambda: UARTDebug::log_string(direction, bytes);
modbus:
uart_id: mod_bus
# flow_control_pin: GPIO4
modbus_controller:
- id: growatt
address: 0x1
modbus_id: modbus1
setup_priority: -10
# update_interval: 30s
text_sensor:
icon: mdi:eye
entity_category: diagnostic
lambda: |-
if ((id(status).state) == 1) {
return {"Normal"};
} else if ((id(status).state) == 0) {
return {"Standby"};
} else if ((id(status).state) == 2) {
return {"Discharge"};
} else if ((id(status).state) == 3) {
return {"Fault"};
} else if ((id(status).state) == 4) {
return {"Flash"};
} else if ((id(status).state) == 5) {
return {"PV Charging"};
} else if ((id(status).state) == 6) {
return {"AC Charging"};
} else if ((id(status).state) == 7) {
return {"Combined Charging"};
} else if ((id(status).state) == 8) {
return {"Combined Charging & Bypass"};
} else if ((id(status).state) == 9) {
return {"PV Charging & Bypass"};
} else if ((id(status).state) == 10) {
return {"AC Charging & Bypass"};
} else if ((id(status).state) == 11) {
return {"Bypass"};
} else if (id(status).state == 12) {
return {"PV Charge and Discharge"};
} else {
return {"Unknown"};
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: 60s
address: 0
internal: true
#### temp ###
name: "${friendly_name} Inverter Temperature"
address: 25
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} PV Temperature"
address: 32
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} DC‐DC Temperature "
address: 26
value_type: U_WORD
filters:
- multiply: 0.1
### ac input ###
name: "${friendly_name} AC Input Hz"
address: 21
device_class: FREQUENCY
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.01
name: "${friendly_name} AC Input Voltage"
address: 20
device_class: VOLTAGE
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} AC Charge Current"
address: 68
device_class: CURRENT
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} AC charge watt (low) "
address: 14
device_class: POWER
icon: mdi:flash
value_type: U_WORD
accuracy_decimals: 2
filters:
- multiply: 0.1
name: "${friendly_name} AC input watt (low) "
address: 37
device_class: POWER
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} AC charge Energy today "
address: 57
unit_of_measurement: KW
device_class: POWER
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
## ac output ##
name: "${friendly_name} Output active power (low) "
address: 10
device_class: power
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} AC output Volt"
address: 22
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} Output Current "
address: 34
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} AC discharge watt (low) "
address: 70
device_class: power
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
## solar ##
name: "${friendly_name} PV1 charge power (high) "
address: 3
unit_of_measurement: Wh
device_class: power
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${friendly_name} PV1 voltage "
address: 1
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} Buck1 current"
address: 7
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} Epv1_today H"
address: 48
value_type: U_DWORD
filters:
- multiply: 0.1
## bat ##
name: "${friendly_name} Battery volt (M3)"
address: 17
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.01
name: "${friendly_name} Bus Voltage"
address: 19
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 0.01
name: "${friendly_name} fan speed"
address: 82
device_class: POWER_FACTOR
icon: mdi:flash
value_type: U_WORD
filters:
- multiply: 1
#### TTL RS485 ####
select:
name: "${friendly_name} Charge Source"
address: 01
value_type: U_WORD
optionsmap:
"Pv Priority": 0
"Pv&Uti": 1
"Only Pv": 2
name: "${friendly_name} Output Source"
address: 02
value_type: U_WORD
optionsmap:
"Bat Priority": 0
"Pv Priority": 1
"Uti Priority": 2
"Pv&Uti Priority": 3
name: "${friendly_name} Uti Output Start Time"
address: 03
value_type: U_WORD
optionsmap:
"0h": 0
"1h": 1
"2h": 2
"3h": 3
"4h": 4
"5h": 5
"6h": 6
"7h": 7
"8h": 8
"9h": 9
"10h": 10
"11h": 11
"12h": 12
"13h": 13
"14h": 14
"15h": 15
"16h": 16
"17h": 17
"18h": 18
"19h": 19
"20h": 20
"21h": 21
"22h": 22
"23h": 23
name: "${friendly_name} Uti Output End Time"
address: 04
value_type: U_WORD
optionsmap:
"0h": 0
"1h": 1
"2h": 2
"3h": 3
"4h": 4
"5h": 5
"6h": 6
"7h": 7
"8h": 8
"9h": 9
"10h": 10
"11h": 11
"12h": 12
"13h": 13
"14h": 14
"15h": 15
"16h": 16
"17h": 17
"18h": 18
"19h": 19
"20h": 20
"21h": 21
"22h": 22
"23h": 23
name: "${friendly_name} Uti Charge Start Time"
address: 05
value_type: U_WORD
optionsmap:
"0h": 0
"1h": 1
"2h": 2
"3h": 3
"4h": 4
"5h": 5
"6h": 6
"7h": 7
"8h": 8
"9h": 9
"10h": 10
"11h": 11
"12h": 12
"13h": 13
"14h": 14
"15h": 15
"16h": 16
"17h": 17
"18h": 18
"19h": 19
"20h": 20
"21h": 21
"22h": 22
"23h": 23
name: "${friendly_name} Uti Charge End Time"
address: 06
value_type: U_WORD
optionsmap:
"0h": 0
"1h": 1
"2h": 2
"3h": 3
"4h": 4
"5h": 5
"6h": 6
"7h": 7
"8h": 8
"9h": 9
"10h": 10
"11h": 11
"12h": 12
"13h": 13
"14h": 14
"15h": 15
"16h": 16
"17h": 17
"18h": 18
"19h": 19
"20h": 20
"21h": 21
"22h": 22
"23h": 23
name: "${friendly_name} PV Input Mode"
address: 07
value_type: U_WORD
optionsmap:
"Independent": 0
"Parallel": 1
name: "${friendly_name} AC Input Mode"
address: 08
value_type: U_WORD
optionsmap:
"APL,90‐280VAC": 0
"UPS,170‐280VAC": 1
name: "${friendly_name} Output Volt Type"
address: 18
value_type: U_WORD
optionsmap:
"208 VAC": 0
"230 VAC": 1
"240 VAC": 2
name: "${friendly_name} Output Freq Type"
address: 19
value_type: U_WORD
optionsmap:
"50 Hz": 0
"60 Hz": 1
name: "${friendly_name} Over Load Restart"
address: 20
value_type: U_WORD
optionsmap:
"Yes": 0
"No": 1
"Swith to UTI": 2
name: "${friendly_name} Over Temperature Restart"
address: 21
value_type: U_WORD
optionsmap:
"Yes": 0
"No": 1
name: "${friendly_name} Buzzer on/off enable"
address: 22
value_type: U_WORD
optionsmap:
"Enable": 0
"Disable": 1
name: "${friendly_name} Maximum Ac Charge Current"
address: 38
value_type: U_WORD
optionsmap: # 0 - 99
"5": 5
"10": 10
"15": 15
"20": 20
"25": 25
"30": 30
"35": 35
"40": 40
"45": 45
"50": 50
"55": 55
"60": 60
"65": 65
"70": 70
"75": 75
"80": 80
"85": 85
"90": 90
"95": 95
name: "${friendly_name} Bat Low Volt Switch To Uti"
address: 37
value_type: U_WORD
optionsmap: # check manual 44 - ??
"44,0": 440
"44,2": 442
"44,6": 446
"44,8": 448
"45,0": 450
"45,2": 452
"45,4": 454
"45,6": 456
"45,8": 458
"46,0": 460
"46,2": 462
# ... ... check the range in the manual
name: "${friendly_name} Mains to battery operating point"
address: 95
value_type: U_WORD
optionsmap:
"48,0": 480
"48,2": 482
"48,4": 484
"48,6": 486
"49,0": 490
"49,2": 492
"49,4": 494
"49,6": 496
"49,8": 498
"50,0": 500
"51,0": 510
"52,0": 520
So cool! Thanks for sharing.
I will give this a go. Is there no youtube tutorial about this?
