I configured and flashed an ESP32 in the ESPHome HA add-on. It is auto-discovery in my HA Integrations, but when I attempt to configure it, it fails. The logs are below. The logging isn’t that helpful, in that I have no idea what JSON file is failing to decode. I assume this is related to the ESP configuration, but I’m not sure.
Any suggestions are appreciated!
HAOS 2023.3.5
ESPHome 2023.3.0
Logger: aiohttp.server
Source: helpers/aiohttp_client.py:67
First occurred: 5:07:30 PM (2 occurrences)
Last logged: 5:07:40 PM
Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 67, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 235, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 146, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 180, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 271, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/esphome/config_flow.py", line 177, in async_step_discovery_confirm
return await self._async_try_fetch_device_info()
File "/usr/src/homeassistant/homeassistant/components/esphome/config_flow.py", line 149, in _async_try_fetch_device_info
and await self._retrieve_encryption_key_from_dashboard()
File "/usr/src/homeassistant/homeassistant/components/esphome/config_flow.py", line 384, in _retrieve_encryption_key_from_dashboard
noise_psk = await dashboard.api.get_encryption_key(device["configuration"])
File "/usr/local/lib/python3.10/site-packages/esphome_dashboard_api/__init__.py", line 103, in get_encryption_key
config = await self.get_config(configuration)
File "/usr/local/lib/python3.10/site-packages/esphome_dashboard_api/__init__.py", line 93, in get_config
return await self.request(
File "/usr/local/lib/python3.10/site-packages/esphome_dashboard_api/__init__.py", line 54, in request
return await resp.json()
File "/usr/src/homeassistant/homeassistant/helpers/aiohttp_client.py", line 67, in json
return await super().json(*args, loads=loads, **kwargs)
File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 1120, in json
return loads(stripped.decode(encoding))
orjson.JSONDecodeError: unexpected character: line 1 column 3282 (char 3281)
