Esphome / mqtt / sensor publish control
I’m looking to see if there is a way to disable mqtt posting on a per sensor basis. I’ve tried to see if the answer has been asked or if it was in the documentation and haven’t found an answer.
mqtt:
  broker: !secret mqtt_broker
  topic_prefix: esphome/test
  log_topic:
    topic: debug
    level: WARN
  - platform: dht
    pin: D4
    model: DHT11
    temperature:
      name: "Living Room Temperature"
      filters:
        - lambda: return x * (9.0/5.0) + 32.0;
      unit_of_measurement: "°F"
    humidity:
      name: "Living Room Humidity"
    update_interval: 60s
  - platform: adc
    pin: VCC
  - platform: adc
    pin: A0
    name: "ESP-2 Gas ADC"
    filters:
      - multiply: 100
    unit_of_measurement: "%"
    icon: "mdi:percent"
binary_sensor:
  - platform: gpio
    device_class: motion
    pin:
      number: D6
      mode:
        input: true
  - platform: gpio
    device_class: light
    pin:
      number: D5
      mode:
        input: true
  - platform: gpio
    pin:
      number: D3
      mode:
        input: true
    name: "Home Multisensor Motion"
    filters:
      - lambda: return x * 0.004882814;
text_sensor:
  - platform: wifi_info
    ip_address:
      name: ESP IP Address
    mac_address:
      name: ESP Mac Wifi Address
interval:
  - interval: 60s
    then:
      - mqtt.publish_json:
          topic: !lambda |-
            return "esphome/sensor/" + id(mac).state;
          payload: |-
            root["name"] = "test";
            root["mac_address"] = id(mac).state;
            root["ip_address"] = id(ip).state;
            root["dht_temperature"] = id(dht_t).state;
            root["dht_temperature_uom"] = "°F";
            root["dht_humidity"] = id(dht_h).state;
            root["dht_humidity_uom"] = "%";
            root["photoresistor"] = id(photoresistor).state;
            root["vcc"] = id(vcc).state;
            root["gas_adc"] = id(gas_adc).state;
In this example I would like the interval and the motion detection to be published to mqtt but the other sensor to not publish (as they would be a duplicate of the interval publishing). Is this possible?
Did you ever find an answer to this? Looking to do the same thing. Can it be disabled on a global basis?
have you found a solution for this??
indeed how to disable publish to MQTT (and so HA) for only specified sensors in ESPHome ?
ChatGpt said: publish: false but that was not a valid option
Just go into the espHome YAML and don’t create the sensors that you don’t want to see?
