im trying to get the payload from an topic into an variable but it does not work i always get an error.
i would like to get an string into a global variable but since i didnt find anything about that i tried to write an INT
what i tried is:
globals:
- id: mqttvalue
type: int
restore_value: yes
initial_value: '0'
- topic: Effect
qos: 1
then:
- globals.set:
value: !lambda |-
return x;
which give me this error:
In file included from src/esphome/components/api/user_services.h:6:0,
from src/esphome/components/api/api_server.h:13,
from src/esphome/components/api/api_connection.h:7,
from src/esphome.h:2,
from src/main.cpp:3:
src/esphome/core/automation.h: In instantiation of 'esphome::TemplatableValue<T, X>::TemplatableValue(F) [with F = setup()::__lambda58; typename std::enable_if<esphome::is_callable<F, X ...>::value, int>::type <anonymous> = 0; T = int; X = {std::basic_string<char, std::char_traits<char>, std::allocator<char> >}]':
src/esphome/components/globals/globals_component.h:70:3: required from 'void esphome::globals::GlobalVarSetAction<C, Ts>::set_value(V) [with V = setup()::__lambda58; C = esphome::globals::RestoringGlobalsComponent<int>; Ts = {std::basic_string<char, std::char_traits<char>, std::allocator<char> >}]'
/config/esphome/wemos.yaml:153:4: required from here
src/esphome/core/automation.h:28:46: error: no matching function for call to 'std::function<int(std::basic_string<char>)>::function(setup()::__lambda58&)'
TemplatableValue(F f) : type_(LAMBDA), f_(f) {}
src/esphome/core/automation.h:28:46: note: candidates are:
In file included from src/esphome/core/component.h:4:0,
from src/esphome/components/api/api_connection.h:3,
/data/cache/platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/4.8.2/functional:2443:7: note: template<class _Functor, class> std::function<_Res(_ArgTypes ...)>::function(_Functor)
function<_Res(_ArgTypes...)>::
/data/cache/platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/4.8.2/functional:2443:7: note: template argument deduction/substitution failed:
/data/cache/platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/4.8.2/functional:2226:7: note: std::function<_Res(_ArgTypes ...)>::function(std::function<_Res(_ArgTypes ...)>&&) [with _Res = int; _ArgTypes = {std::basic_string<char, std::char_traits<char>, std::allocator<char> >}]
function(function&& __x) : _Function_base()
/data/cache/platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/4.8.2/functional:2226:7: note: no known conversion for argument 1 from 'setup()::__lambda58' to 'std::function<int(std::basic_string<char>)>&&'
/data/cache/platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/4.8.2/functional:2429:5: note: std::function<_Res(_ArgTypes ...)>::function(const std::function<_Res(_ArgTypes ...)>&) [with _Res = int; _ArgTypes = {std::basic_string<char, std::char_traits<char>, std::allocator<char> >}]
/data/cache/platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/4.8.2/functional:2429:5: note: no known conversion for argument 1 from 'setup()::__lambda58' to 'const std::function<int(std::basic_string<char>)>&'
/data/cache/platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/4.8.2/functional:2206:7: note: std::function<_Res(_ArgTypes ...)>::function(std::nullptr_t) [with _Res = int; _ArgTypes = {std::basic_string<char, std::char_traits<char>, std::allocator<char> >}; std::nullptr_t = std::nullptr_t]
function(nullptr_t) noexcept
/data/cache/platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/4.8.2/functional:2206:7: note: no known conversion for argument 1 from 'setup()::__lambda58' to 'std::nullptr_t'
/data/cache/platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/4.8.2/functional:2199:7: note: std::function<_Res(_ArgTypes ...)>::function() [with _Res = int; _ArgTypes = {std::basic_string<char, std::char_traits<char>, std::allocator<char> >}]
function() noexcept
/data/cache/platformio/packages/toolchain-xtensa/xtensa-lx106-elf/include/c++/4.8.2/functional:2199:7: note: candidate expects 0 arguments, 1 provided
*** [/data/elekstube/.pioenvs/elekstube/src/main.cpp.o] Error 1
========================== [FAILED] Took 2.08 seconds ==========================
i also tried
- topic: Effect
qos: 1
then:
- lambda: |-
id(mqttvalue) = int(x);
#and also --> id(mqttvalue) = x;
/config/esphome/wemos.yaml: In lambda function:
/config/esphome/wemos.yaml:148:33: error: invalid cast from type 'std::string {aka std::basic_string<char>}' to type 'int'
how can i solve that?
