finity
January 27, 2020, 7:03pm
1
I’m trying to transition my wifi AP’s to different SSID’s. So I’m trying to make sure the ESPHome nodes can connect to the new one before I remove the old so I figured I’d set up the Sonoff to use multiple networks.
Per the docs the config is:
wifi:
networks:
- ssid: !secret wifi_ssid
password: !secret wifi_pwd
- ssid: !secret wifi_ssid_2
But for some reason it won’t connect to either SSID.
I have validated the config and it is valid.
If I remove the second SSID and reflash everything works fine.
So this works:
wifi:
networks:
#- ssid: !secret wifi_ssid_2
# password: !secret wifi_pwd
Am I missing something?
finity
January 27, 2020, 7:40pm
2
@Tinkerer
thanks for fixing that. I knew I had seen an ESPHome tag before but I couldn’t remember where and couldn’t find it in my quick search.
dougle03
(Peter Kay)
January 28, 2020, 7:22pm
3
How did you solve it? or am I missing something,…?
finity
January 28, 2020, 7:25pm
4
No, sorry. It’s not solved yet.
I was commenting on the fact that he changed the thread section & tags to “third party integrations” & " ESPHome".
Sorry for the confusion.
laca75tn
(My Home)
February 1, 2020, 2:56pm
5
I was having the same problem and it was that one of my SSIDs had spaces on the name and I didn’t have it in between quotes.
wifi:
networks:
- ssid: "MyFirstOption"
password: "myfirstpassword"
- ssid: "My Second Option"
finity
February 1, 2020, 6:30pm
6
We have a winner!
I haven’t tried it yet but that does exactly match my scenario so I can’t imagine that wouldn’t be it.
If it doesn’t work I’ll definitely let you know.
Thanks!
I have the same issue and no space in the SSID or in the password. Not even sure how to use the quotes if you use a secrets file for those data… I think there’s another explanation…
dougle03
(Peter Kay)
September 18, 2021, 11:35am
8
I had this where one of my passwords was only numbers; I put it in “1234” and now it passes validation.
pedjas
(Pedjas)
December 13, 2022, 4:53pm
9
I had the same issue, SSID had space but I did place it within quotes.
The only resolution was to change SSID not to have space.
