Hello
i want to create display for some sensors from HA using nextion display and esp8266 d1 mini v2 and esphome api.
I wrote my yaml code by modifying:
GitHub - bruxy70/Home-Assistant-ESPHome-Weather-Station: Nextion display with ESP8266 microcontroller (Wemos D1 mini) showing Home Assistant temperature sensors and weather forecast
but i recive value “nan” from HA sensor. Accordin to my reserch that kind of value apear when esphome node wasn’t added to HA integrations but i did it and nothing heppends…
hire is my extra minimalistic yaml code for esphome node:
esphome:
platform: ESP8266
board: esp01_1m
# Enable logging
logger:
baud_rate: 0 # Disable UART logging (pins GPIO1/3 are used for Nextion communication)
level: VERBOSE
# Enable Home Assistant API
api:
password: "****" #passoword was set in HA configuration.yaml
ota:
password: "*****" #this pass was auto generated
wifi:
ssid: "****"
password: "*****"
fast_connect: true
manual_ip:
static_ip: 192.168.0.173
gateway: 192.168.0.1
subnet: 255.255.255.0
ap:
ssid: "Nextion-Display-1"
password: "M9ZCdnlzkfnP"
captive_portal:
uart:
rx_pin: GPIO3
tx_pin: GPIO1
baud_rate: 9600
- platform: homeassistant # outside temperature
entity_id: sensor.a4c138360801_humidity #there was temp sensor but i try another one... i didn't change sensor ID
display:
- platform: nextion
update_interval: 1s
lambda: |- #I try different way to display variable
it.set_component_value("tempoutside",id(temp_outside).state); #it's not working even nan value
it.set_component_text_printf("tempoutside","%f",id(temp_outside).state); #it's show nan walue
it.set_component_text_printf("text","text_testowy"); #it's show text_testowy on diplay corretly
and there is log form esphome node in VERBOSE mode:
INFO Reading configuration /config/esphome/nextion-display-1.yaml...
INFO Detected timezone 'Europe/Warsaw'
INFO Starting log output from 192.168.0.173 using esphome API
INFO Successfully connected to 192.168.0.173
[17:58:05][I][app:099]: ESPHome version 2021.10.3 compiled on Oct 27 2021, 17:33:19
[17:58:05][C][wifi:490]: WiFi:
[17:58:05][C][wifi:352]: Local MAC: 48:3F:DA:48:FB:4F
[17:58:05][C][wifi:353]: SSID: [redacted]
[17:58:05][C][wifi:354]: IP Address: 192.168.0.173
[17:58:05][C][wifi:356]: BSSID: [redacted]
[17:58:05][C][wifi:357]: Hostname: 'nextion-display-1'
[17:58:05][C][wifi:359]: Signal strength: -59 dB ▂▄▆█
[17:58:05][C][wifi:363]: Channel: 11
[17:58:05][C][wifi:364]: Subnet: 255.255.255.0
[17:58:05][C][wifi:365]: Gateway: 192.168.0.1
[17:58:05][C][wifi:366]: DNS1: 0.0.0.0
[17:58:05][C][wifi:367]: DNS2: 0.0.0.0
[17:58:05][C][uart.arduino_esp8266:095]: UART Bus:
[17:58:05][C][uart.arduino_esp8266:096]: TX Pin: GPIO1
[17:58:05][C][uart.arduino_esp8266:097]: RX Pin: GPIO3
[17:58:05][C][uart.arduino_esp8266:099]: RX Buffer Size: 256
[17:58:05][C][uart.arduino_esp8266:101]: Baud Rate: 9600 baud
[17:58:05][C][uart.arduino_esp8266:102]: Data Bits: 8
[17:58:05][C][uart.arduino_esp8266:103]: Parity: NONE
[17:58:05][C][uart.arduino_esp8266:104]: Stop bits: 1
[17:58:05][C][uart.arduino_esp8266:106]: Using hardware serial interface.
[17:58:05][C][logger:233]: Logger:
[17:58:05][C][logger:234]: Level: VERBOSE
[17:58:05][C][logger:235]: Log Baud Rate: 0
[17:58:05][C][logger:236]: Hardware UART: UART0
[17:58:05][C][nextion:117]: Nextion:
[17:58:05][C][nextion:118]: Device Model: NX3224T028_011R
[17:58:05][C][nextion:119]: Firmware Version: 163
[17:58:05][C][nextion:120]: Serial Number: DE6784385F572138
[17:58:05][C][nextion:121]: Flash Size: 4194304
[17:58:05][C][nextion:122]: Wake On Touch: True
[17:58:05][C][captive_portal:150]: Captive Portal:
[17:58:05][C][ota:082]: Over-The-Air Updates:
[17:58:05][C][ota:083]: Address: 192.168.0.173:8266
[17:58:05][C][ota:086]: Using Password.
[17:58:05][C][api:134]: API Server:
[17:58:05][C][api:135]: Address: 192.168.0.173:6053
[17:58:05][C][api:139]: Using noise encryption: NO
[17:58:05][C][sntp:044]: SNTP Time:
[17:58:05][C][sntp:045]: Server 1: '0.pool.ntp.org'
[17:58:05][C][sntp:046]: Server 2: '1.pool.ntp.org'
[17:58:05][C][sntp:047]: Server 3: '2.pool.ntp.org'
[17:58:05][C][sntp:048]: Timezone: 'CET-1CEST,M3.5.0,M10.5.0/3'
[17:58:05][C][homeassistant.sensor:030]: Homeassistant Sensor 'temp_outside'
[17:58:05][C][homeassistant.sensor:030]: State Class: ''
[17:58:05][C][homeassistant.sensor:030]: Unit of Measurement: ''
[17:58:05][C][homeassistant.sensor:030]: Accuracy Decimals: 1
[17:58:05][C][homeassistant.sensor:031]: Entity ID: 'sensor.a4c138360801_humidity'
[17:58:06][D][api:098]: Accepted 192.168.0.189
[17:58:06][V][api.connection:720]: Hello from client: 'Home Assistant 2021.10.6 (192.168.0.189)'
[17:58:07][D][api:098]: Accepted 192.168.0.189
[17:58:07][V][api.connection:720]: Hello from client: 'Home Assistant 2021.10.6 (192.168.0.189)'
[17:58:08][D][api:098]: Accepted 192.168.0.189
[17:58:08][V][api.connection:720]: Hello from client: 'Home Assistant 2021.10.6 (192.168.0.189)'
[17:58:09][D][api:098]: Accepted 192.168.0.189
[17:58:09][V][api.connection:720]: Hello from client: 'Home Assistant 2021.10.6 (192.168.0.189)'
[17:58:10][D][api:098]: Accepted 192.168.0.189
[17:58:11][V][api.connection:720]: Hello from client: 'Home Assistant 2021.10.6 (192.168.0.189)'
it’s stop after recive this messages and after 1min this message repeat. On display still I see nan value…
