ok, can be done. in the editor need to set “isbr” to true.
Question is now black (burned)
Dear People, I have a problem with my esphome configuration with an nextion display. Actually I have it completely working, only I get an annoying message. I use a number of sensors that I want to show on page 3. Now I have the config so that this also happens. But if I am now on a different page then I get a warning (yellow) in my log from my esphome (see attachment). I expect to somehow have to point my sensors to page3 but I just don’t know how to do this. i hope you can help me with this.
CODE ESPHOME
uart:
rx_pin: D9
tx_pin: D10
baud_rate: 9600
display:
platform: nextion
update_interval: 1s
lambda: |-
it.set_wait_for_ack(false);auto time_text = id(sntp_time).now().strftime("%X"); it.set_component_text("text_time", time_text.c_str()); auto date_text = id(sntp_time).now().strftime("%x"); it.set_component_text("text_date", date_text.c_str()); auto week_text = id(sntp_time).now().strftime("%W"); it.set_component_text("weeknr", week_text.c_str()); auto time = id(sntp_time).now(); it.set_component_text_printf("hour","%02d",time.hour); it.set_component_text_printf("minut","%02d",time.minute); it.set_component_text_printf("outside","%2.1f", id(temp).state); it.set_component_text_printf("vocht","%2.1f", id(vocht).state); it.set_component_text_printf("rain","%2.1f", id(rain).state); it.set_component_text_printf("lux","%2.1f", id(lux).state); it.set_component_text_printf("luxin","%2.1f", id(lux_woonkamer).state); it.set_component_text_printf("vochtin","%2.1f", id(hum_woonkamer).state); it.set_component_text_printf("inside","%2.1f", id(temp_woonkamer).state);
time:
- platform: sntp
platform: homeassistant
entity_id: sensor.sensor_box_am2301_13_temperature -
entity_id: sensor.sensor_box_am2301_13_humidity -
entity_id: sensor.tfa_80_0c_rain_total -
entity_id: sensor.sensor_box_bh1750_illuminance -
platform: wifi_signal
name: “WiFi signal HMI”
update_interval: 60s -
platform: hdc1080
temperature:
humidity:
update_interval: 5s -
platform: bh1750
address: 0x23
measurement_time: 69
update_interval: 5s
i2c:
sda: D2
scl: D1
scan: False
binary_sensor:
platform: nextion
page_id: 1
component_id: 3
platform: nextion
page_id: 1
component_id: 6
platform: nextion
page_id: 1
component_id: 4
platform: nextion
page_id: 1
component_id: 8
platform: nextion
page_id: 1
component_id: 5
platform: nextion
page_id: 1
component_id: 7
platform: nextion
page_id: 4
component_id: 3
platform: nextion
page_id: 4
component_id: 5
platform: nextion
page_id: 4
component_id: 6
platform: nextion
page_id: 4
component_id: 4
platform: nextion
page_id: 4
component_id: 10
platform: nextion
page_id: 4
component_id: 9
platform: nextion
page_id: 4
component_id: 8
platform: nextion
page_id: 4
component_id: 7
switch:
platform: restart
name: “Reset HMI” -
platform: shutdown
output:
- platform: esp8266_pwm
pin: D8
light:
- platform: monochromatic
output: pwm_output
WARNINGS
[23:58:09][D][nextion:209]: Got touch page=3 component=1 type=PRESS
[23:58:10][W][nextion:177]: Nextion reported variable name invalid!
Please format all your code correctly.
What do you mean ?
Hi!
I’m trying to display the state of the binary sensor ON and OFF, I can’t display it on the screen, I’ve tried various options but unsuccessfully.
- platform: homeassistant # Kitchen window
entity_id: sensor.window_kitchen
and
display:
- platform: nextion
update_interval: 5s
lambda: |-
it.set_component_text_printf("winkitchen","%",id(win_kitchen).state);
I try %s (String of characters) but nothing. How to print binary state of sensor?
Log of esphome [00:15:32][W][homeassistant.sensor:014]: Can’t convert ‘ON’ to number!
P.S. It is work i understand
text_sensor:
and
it.set_component_text_printf("winkitch","%s",id(win_kitchen).state.c_str());
I try to get mine to work but I got error from the esphome log screen “received unknown filler end bytes from Nextion!”. What did I do wrong? I check all the examples but unable to get it to work with esphome.
On the esphome long it showed message of “Sending command ‘t0.txt=Hellooo’ failed because no ACK was received … : Waiting for ACK timed out!” but nothing on the display. I flip the tx and rx but still same result.
I’m plugging my nextion PR for esphome.
It has a ton of improvements, including tft Ota. We are working hard on getting this merged.
Been following what your are doing and thanks for that.
Will the documentation also be updated?
There is a PR for it and will be updated once we get closer to merging. I actually am planning on updating it soon though.
Hi!
Did you solve this?
Hi, long time no see. After a few updates of a lot of stuff further my text sensor is not properly filled anymore in the display. Also I get errors but I do not know what they mean. Anyone able to direct?
[12:40:46][C][api:143]: Using noise encryption: NO
[12:40:46][C][homeassistant.text_sensor:023]: Homeassistant Text Sensor 't10_text'
[12:40:46][C][homeassistant.text_sensor:024]: Entity ID: 'sensor.nextiont0_text'
[12:40:46][C][homeassistant.text_sensor:023]: Homeassistant Text Sensor 'dim_text'
[12:40:46][C][homeassistant.text_sensor:024]: Entity ID: 'sensor.nextiondim_text'
[12:40:46][C][homeassistant.text_sensor:023]: Homeassistant Text Sensor 'uart_text'
[12:40:46][C][homeassistant.text_sensor:024]: Entity ID: 'sensor.nextion_uart'
[12:40:49][E][nextion:1107]: This command is deprecated
[12:40:49][V][component:199]: Component nextion.display took a long time for an operation (0.08 s).
[12:40:49][V][component:200]: Components should block for at most 20-30ms.
[12:40:49][W][nextion:395]: Nextion reported variable name invalid!
[12:40:54][E][nextion:1107]: This command is deprecated
[12:40:54][V][component:199]: Component nextion.display took a long time for an operation (0.08 s).
[12:40:54][V][component:200]: Components should block for at most 20-30ms.
[12:40:54][W][nextion:395]: Nextion reported variable name invalid!
[12:40:59][E][nextion:1107]: This command is deprecated
[12:40:59][V][component:199]: Component nextion.display took a long time for an operation (0.08 s).
[12:40:59][V][component:200]: Components should block for at most 20-30ms.
[12:40:59][W][nextion:395]: Nextion reported variable name invalid!
[12:41:04][E][nextion:1107]: This command is deprecated
[12:41:04][V][component:199]: Component nextion.display took a long time for an operation (0.08 s).
[12:41:04][V][component:200]: Components should block for at most 20-30ms.
[12:41:04][W][nextion:395]: Nextion reported variable name invalid!
[12:41:09][E][nextion:1107]: This command is deprecated
[12:41:09][V][component:199]: Component nextion.display took a long time for an operation (0.08 s).
[12:41:09][V][component:200]: Components should block for at most 20-30ms.
[12:41:09][W][nextion:395]: Nextion reported variable name invalid!
What command is deprecated?
I believe this is relevant:
uart:
rx_pin: D7
tx_pin: D5
baud_rate: 9600
display:
- platform: nextion
lambda: |-
it.set_component_text("t10", id(t10_text).state.c_str());
text_sensor:
entity_id: sensor.nextiont0_text
entity_id: sensor.nextiondim_text
entity_id: sensor.nextion_uart
There must be more code.
The log says you are asking for a variable from nextion that does not exist.
This is all regarding nextion
uart:
rx_pin: D7
tx_pin: D5
baud_rate: 9600
display:
- platform: nextion
lambda: |-
text_sensor:
binary_sensor:
- platform: nextion
page_id: 0
component_id: 3
- platform: nextion
page_id: 1
component_id: 2
name: "Nextion.Button.Package delivered"
- platform: nextion
page_id: 1
component_id: 3
name: "Nextion.Button.Package not delivered"
- platform: nextion
page_id: 2
component_id: 1
- platform: nextion
page_id: 2
component_id: 2
- platform: nextion
page_id: 2
component_id: 3
- platform: nextion
page_id: 0
component_id: 2
- platform: nextion
page_id: 6
component_id: 5
- platform: nextion
page_id: 6
component_id: 6
switch:
- platform: uart
data: 'dim=1'
- platform: uart
data: 'dim=20'
- platform: uart
data: 'dim=100'
- platform: uart
data: [0xFF, 0xFF, 0xFF]
These are the nextion variables, make sure all is still in the tft/hmi file
100% all is in. It used to work when I made it at that time. No errors then.
But what does these mean:
[13:53:56][E][nextion:1107]: This command is deprecated
[13:53:56][V][component:199]: Component nextion.display took a long time for an operation (0.08 s).
[13:53:56][V][component:200]: Components should block for at most 20-30ms.
[13:53:56][W][nextion:395]: Nextion reported variable name invalid!
First three don’t know for sure.
The last one is that the ESP is asking for a variable that is not there or not global.
My guess is that the fourth one is the reason for the other three.
Ok, but how do I discover what command is deprecated then?
