Hi, I’m having a problem,
I’m using ESPHome and everything works fine, I can control my relay from the HA dashboard, but when the relay change its state from the device itself, it doesn’t update the new state to the dashboard.
Could anyone help please?
It seems like it’s a one way communication, wich is false since I can get the temperature on my dashboard.
Her’s my config (on a pico w)
#Temperature
dallas:
- pin: GPIO22
update_interval: 5s
- platform: dallas
address: 0x6b0301a279658b28
name: "temp_in" #with resistance
- platform: dallas
address: 0x8d0301a279dd0728
on_value:
then:
- script.execute: ventilation
#Ventilation
output:
- id: fan_output
platform: gpio
pin: GPIO21
fan:
- platform: binary
output: fan_output
script:
- id: ventilation
then:
- if:
condition:
lambda: |-
return id(temp_in).state >= id(temp_out).state + 0.5;
then:
- output.turn_on: fan_output
- if:
condition:
lambda: |-
return id(temp_in).state <= id(temp_out).state;
then:
- output.turn_off: fan_output
Here i clicked to toogle the fan relay, the relay turns on correctly, then it turns off because of my config (wich is normal) but stays on here, same problem the other way
