I have an ESP32 device that I have just flashed using ESP web
It has been discovered by HA, and I have flashed a basic config to the device from the ESPHome HA web portal
I have ensured that the API key in the yaml matches the string given to me when HA discovered the device
I have ensured that the “Allow device to call HA services” checkbox is ticked
However, whatever I do, I get the following error whenever I try to update a sensor using the API:
Logger: aioesphomeapi.connection
Source: runner.py:179
First occurred: 15:18:25 (16 occurrences)
Last logged: 15:55:25
192.168.1.158: Connection error occurred: Connection requires encryption
esphome-web-065eb0 @ 192.168.1.158: Connection error occurred: [Errno 104] Connection reset by peer
192.168.1.158: Connection error occurred: Invalid encryption key: received_name=esphome-web-065eb0
esphome-rain @ 192.168.1.158: Connection error occurred: [Errno 104] Connection reset by peer
192.168.1.158: Connection error occurred: Invalid encryption key: received_name=esphome-rain
And the code itself:
esphome:
friendly_name: ESPHome Web 065eb0
on_boot:
then:
- wait_until:
condition:
api.connected:
- homeassistant.service:
service: counter.increment
entity_id: counter.total_tips
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "OXJawYNUs87X94Don83ACc4jV8U9XlQhVNGDqaqpfzg="
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-065Eb0"
password: "3fZXCesDocqb"
captive_portal:
